- Mute
- Permalink
- Report
I need to change the reference of derived parameter table from one document to another with the same names of model parameters to which it will be linked to. Unfortunatelly it is not working by simply changing the reference file so the sollution is to firstly delete original derived parameter table, and then create new derived parameter table with reference to a new document.
The problem is, I cannot get the original name of parameter from which the derived parameter was created. It is easy to do it manually - right click on derived parameters table in Parameters window and then select Edit Folder (see attached image).
It is any method to get original names via iLogic/VBA (dirrectly or indirectly by workarround)?
Thank you a lot!
Download the prerelease of Hole Projector for Inventor 2027
