Get name of current assembly, when editing sub-assemblies
pball
Mentor Mentor
pball
I have a script which currently references ThisApplication.ActiveDocument which is fine if you are in the top level assembly. But when I go into a sub-assembly to edit it, I would like the script to get the name of the sub-assembly.
So is there a simple way to get the name of the sub-assembly you are currently editing?
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
This scriptlet will give the name of the object you are currently editing.
1. - Checks if the current document is an assembly. If it is given a message and exits.
2. - Displays the name of the document currently being edited
A Sub-assembly o Part that is being edited) If you're not editing anything,
gives the name of the parent assembly.
** You should now catch the type of document being edited to make other functions on it, for example.
Public Sub DameNombre()
    If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
        MsgBox ("Macro only for Assembly")
        End
    End If
    If ThisApplication.ActiveEditDocument.DocumentType = kAssemblyDocumentObject Then
        MsgBox ("Sub-Assembly name = " & ThisApplication.ActiveEditDocument.DisplayName)
    Else
        MsgBox ("Part name = " & ThisApplication.ActiveEditDocument.DisplayName)
    End If
End Sub
