I'm not so sure how useful this is for drawings of part files. but her you go:
Dim Title As String = "Excitech iLogic"
Dim Counter As Integer = 0
Dim SketchName As String = "Sketch 1"
Dim doc As DrawingDocument = ThisDoc.Document
Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a view to toggle sketch visibility, or hit ESC to cancel...")
If view Is Nothing Then
Exit Sub
SketchName = InputBox("Please enter name of sketch to toggle visibility.", Title, SketchName)
Dim refDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
If refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
MsgBox("The referenced document needs to be an part. Exiting", MsgBoxStyle.OkOnly, Title)
Exit Sub
Dim def As PartComponentDefinition = refDoc.ComponentDefinition
Dim sketches As PlanarSketches = def.Sketches
For Each sketch As PlanarSketch In sketches
If Sketch.Name = SketchName Then
Counter += 1
Dim current As Boolean = view.GetIncludeStatus(Sketch)
view.SetIncludeStatus(Sketch, Not current)
Next
If Counter = 0 Then
MsgBox("No sketches called " & SketchName & " were found in this view.", MsgBoxStyle.OkOnly, Title)
Jelte de Jong
Blog: hjalte.nl - github.com
