Get model sketch
Get model sketch
madstrolle
Get model sketch
madstrolle
I have looked for a way to get model sketches to my part file in a drawing.
I found this blog, which is exactly what i'm looking for (code is in the article):
https://www.symetri.co.uk/insights/blog/autodesk-inventor-2017-ilogic-identify-parts-in-layout-drawi...
Unfortunately i can't get it to workâ˜šī¸
Maybe it's because this code is made for assemblies? I'm green when it comes to Ilogic coding đŸ™ƒ
Is there anybody out there that can help me with this?
Thanks in advance đŸ™‚
JelteDeJong
I'm not so sure how useful this is for drawings of part files. but her you go:
Dim Title As String = "Excitech iLogic"
Dim Counter As Integer = 0
Dim SketchName As String = "Sketch 1"
Dim doc As DrawingDocument = ThisDoc.Document
Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a view to toggle sketch visibility, or hit ESC to cancel...")
If view Is Nothing Then
    Exit Sub
End If
SketchName = InputBox("Please enter name of sketch to toggle visibility.", Title, SketchName)
Dim refDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
If refDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
    MsgBox("The referenced document needs to be an part. Exiting", MsgBoxStyle.OkOnly, Title)
    Exit Sub
End If
Dim def As PartComponentDefinition = refDoc.ComponentDefinition
Dim sketches As PlanarSketches = def.Sketches
For Each sketch As PlanarSketch In sketches
    If Sketch.Name = SketchName Then
        Counter += 1
        Dim current As Boolean = view.GetIncludeStatus(Sketch)
        view.SetIncludeStatus(Sketch, Not current)
    End If
Next
If Counter = 0 Then
    MsgBox("No sketches called " & SketchName & " were found in this view.", MsgBoxStyle.OkOnly, Title)
End If
Jelte de Jong
Blog: hjalte.nl - github.com
madstrolle
Working perfect.
Thank you 🙂
