Get iLogic forms in a document
gustavo.cassel
gustavo.cassel
Hello, i'm developing an C# addin for Inventor 2023.
I've already managed a way to get all the rules in a determined document and remove each one.
I want a way to get all existing forms in the document and delete.
Here is what I already have:
const string iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}";
Inventor.ApplicationAddIn addin;
try
    addin = Global.InventorApplication.ApplicationAddIns.get_ItemById(iLogicAddinGuid);
catch
{ return; }
Document document = Global.InventorApplication.ActiveDocument;
if (addin != null)
    if (!addin.Activated)
        addin.Activate();
    dynamic automation = addin.Automation;
    System.Collections.IEnumerable ruleCol = automation.get_Rules(document);
    if (ruleCol is null)
        MessageBox.Show("empty");
        return;
    else
        foreach (dynamic item in ruleCol)
            MessageBox.Show(item.Name);
        automation.DeleteAllRulesInDocument(document);
WCrihfield
Hi @gustavo.cassel.  The specifications for internal iLogic forms are stored in Bit Arrays within document level Attributes.  So you can delete them by deleting the AttributeSet(s) that hold their data.  Here is a link to a related post.  And here is a simple vb.net example code for deleting all internal iLogic forms from the active document.
Dim oDoc As Document = ThisApplication.ActiveEditDocument
Dim oASets As AttributeSets = oDoc.AttributeSets
If oASets.Count = 0 Then Logger.Info("No AttributeSets") : Exit Sub
For Each oASet As AttributeSet In oASets
	'the AttributeSet.Name should start with "iLogicInternalUi"
	If oASet.Name Like "iLogicInternalUi*" Then oASet.Delete
Next
'toggle visibility of iLogic dockable window to update it
For Each oDW As Inventor.DockableWindow In ThisApplication.UserInterfaceManager.DockableWindows
	If oDW.InternalName = "ilogic.treeeditor" Then
		oDW.Visible = False
		oDW.Visible = True
	End If
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
