Get Hole Notes From IDW
Boleivia
Boleivia
I am working on some VB code to reterive the dimensions fron an IDW and put  them on an excel spreadsheet for an Inspection report. I found some code to which gets the linear dimensions and have added tolerance type and tolerance bands. All this works good.
I have been unable to get the hole notes off the IDW. Got the general notes to work with the following Code:
Dim invDrawNotes As Inventor.DrawingNotes
    Dim invActDrawNotes As Inventor.DrawingNote
    Set invDrawNotes = invActSHT.DrawingNotes
        For Each invActDrawNotes In invDrawNotes
          Debug.Print invActDrawNotes.Text
          exCells(intIndex, 3) = invActDrawNotes.Text
          exCells(intIndex, 5) = "Note"
          exCells(intIndex, 6).Value = strSheetName
          intIndex = intIndex + 1
        Next
Im trying this code to get the Hole Notes. The code finds the holes and lists their properties but what I'm after is the hole note text which i can seem to get at. Are the hole notes text exposed  and which object should I be looking at?
'Get Threaded Holess
    Dim invHoleThreadNotes As Inventor.HoleThreadNotes
    Dim invActHoleThreadNotes As Inventor.HoleThreadNote
    Set invHoleThreadNotes = invActSHT.DrawingNotes.HoleThreadNotes
        For Each invActHoleThreadNotes In invHoleThreadNotes
          Debug.Print invActHoleThreadNotes.FormattedHoleThreadNote, "Found Hole"
          Debug.Print invActHoleThreadNotes.Hole
        Next
Any Help would be appericated.
Scott
alewer
I believe that the HoleThreadNote.Text.Text property will work. Try replacing your For/Next loop with this:
  Dim oHoleNote As Inventor.HoleThreadNote
  For Each oHoleNote In invActSHT.DrawingNotes.HoleThreadNotes
    Debug.Print oHoleNote.Text.Text
  Next
Let me know if it works or if you have any more questions. Good luck!
Boleivia
Works perfect thanks for your help. I guess I need to do some reading on navigating object models, any suggestions
Thanks again
alewer
To get the object model: If you haven't already installed the developer tools, I suggest that you do (directions here).
Perhaps more importantly, learn to use break points and watches in VBA. This blog post describes one technique. To answer your question, I added a watch on the sheet object and stepped through the macro. Using the watch, I found the Text.Text property in seconds.
