- Mute
- Permalink
- Report
I am working on some VB code to reterive the dimensions fron an IDW and put them on an excel spreadsheet for an Inspection report. I found some code to which gets the linear dimensions and have added tolerance type and tolerance bands. All this works good.
I have been unable to get the hole notes off the IDW. Got the general notes to work with the following Code:
Dim invDrawNotes As Inventor.DrawingNotes
Dim invActDrawNotes As Inventor.DrawingNote
Set invDrawNotes = invActSHT.DrawingNotes
For Each invActDrawNotes In invDrawNotes
Debug.Print invActDrawNotes.Text
exCells(intIndex, 3) = invActDrawNotes.Text
exCells(intIndex, 5) = "Note"
exCells(intIndex, 6).Value = strSheetName
intIndex = intIndex + 1
Next
Im trying this code to get the Hole Notes. The code finds the holes and lists their properties but what I'm after is the hole note text which i can seem to get at. Are the hole notes text exposed and which object should I be looking at?
'Get Threaded Holess
Dim invHoleThreadNotes As Inventor.HoleThreadNotes
Dim invActHoleThreadNotes As Inventor.HoleThreadNote
Set invHoleThreadNotes = invActSHT.DrawingNotes.HoleThreadNotes
For Each invActHoleThreadNotes In invHoleThreadNotes
Debug.Print invActHoleThreadNotes.FormattedHoleThreadNote, "Found Hole"
Debug.Print invActHoleThreadNotes.Hole
Next
Any Help would be appericated.
Scott
