Get Dimension of sketch to Iproperties
haphanthanhtam.work
Message 1 of 18
haphanthanhtam.work
I have a problem to solve
I made in part
First, I show DIMENSION
Then I pick a value of DIMENSION in Sketch
And save it auto as "L1" in the CUSOM of IPROPERTIES
Replies (17)
Message 2 of 18
A.Acheson
Hi @haphanthanhtam.work
You can export a model parameter to iproperty by opening the parameter tab and ticking the export button. Here is an article that shows the manual method and retrieving the parameter by code.
Regards
Alan
Message 3 of 18
haphanthanhtam.work
Hi @A.Acheson
thanks for the answer. But for some reason I need to do it in a way of picking each value on Sketch.
you can create a code to do that?
Message 4 of 18
WCrihfield
Hi @haphanthanhtam.work.  Yes, it is possible to pick a DimensionConstraint within a Sketch, then get the Parameter it represents, then try to expose that Parameter as a custom iProperty.  Here is a simple example iLogic code like that:
oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchDimConstraintFilter, "Select a Sketch Dimensional Constraint.")
If oObj Is Nothing OrElse (TypeOf oObj Is DimensionConstraint = False) Then Exit Sub
Dim oDimConst As DimensionConstraint = oObj
Dim oParam As Inventor.Parameter = oDimConst.Parameter
Try
	oParam.ExposedAsProperty = True
Catch
	MsgBox("Error trying to expose the parameter as a custom iProperty!", vbCritical, "Failure")
End Try
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 18
haphanthanhtam.work
Hi @WCrihfield Yes
it can output But I need to assign it with a custom name
for ex:
iProperties.Value(oDocFileName, "Custom", "Custom name") = output value
Message 6 of 18
Curtis_Waguespack
See this example for renaming the exported iProperty, processing the entire sketch.
I hope this helps.
Curtis
'example expects a parameter named something like E_Width
'results in an iproperty named something like L_Width
Dim oDoc As PartDocument = ThisDoc.Document
Dim oSketch As PlanarSketch = oDoc.ComponentDefinition.Sketches.Item("Sketch1")
Dim oDimConstraint As DimensionConstraint
For Each oDimConstraint In oSketch.DimensionConstraints
	Dim oParameter As Inventor.Parameter = oDimConstraint.Parameter
	'only export parameters with E_ in the name
	Try : oParameter.ExposedAsProperty = oParameter.Name.Contains("E_")
	Catch : Logger.Info(oParameter.Name & " not exported") : End Try
Next
'rename exported iproperty
For Each oProp As Inventor.Property In oDoc.PropertySets.Item("User Defined Properties")
	If oProp.Name.Contains("E_") Then
		Try : oProp.DisplayName = oProp.Name.Replace("E_", "L_") : Catch : End Try
	End If
Next
Message 7 of 18
Curtis_Waguespack
Hi @haphanthanhtam.work ,
Here's another example using WCrihfield's pick method example.
I hope this helps.
Curtis
Try
	oParam.ExposedAsProperty = False 'set to false, to ensure it is exported again
Catch
End Try
oProp = ThisDoc.Document.PropertySets.Item("User Defined Properties").Item(oParam.Name)
ThisDoc.Document.PropertySets.Item("User Defined Properties").Item(oParam.Name).DisplayName  = "L_" & oProp.DisplayName
Message 8 of 18
WCrihfield
OK. Here is another similar example that does not try to expose the parameter, and instead just tries to create (or update) a custom iProperty, using the 'Expression' of the Parameter.  The Expression is a String, and usually includes the units specifier, just like you see it in the Parameters dialog.  But it can also contain an equation, which might mess things up here.  But the Value and ModelValue of a Parameter API object is always in 'database units' instead of document units or the parameter's own units, that's why I'm trying to use the Expression instead.  Using the simple Parameter() method could be risky when used within an assembly scenario, and trying to control another document, so I stuck with API methods instead here.
Dim oDoc As Document = Nothing
Try : oDoc = oParam.Parent : Catch : End Try
If oDoc Is Nothing Then Exit Sub
If oDoc.IsModifiable = Fasle Then Exit Sub 'can't create the custom property in it, or change its value
Dim oCProps As PropertySet = oDoc.PropertySets.Item(4)
Dim oCProp As Inventor.Property = Nothing
Dim oCPropName As String = "Custom name"
Try
	oCProp = oCProps.Item(oCPropName)
Catch
	oCProp = oCProps.Add(oParam.Expression, oCPropName)
End Try
If oCProp IsNot Nothing AndAlso oCProp.Value <> oParam.Expression Then
	oCProp.Value = oParam.Expression
End If
Edit:  You could swap out this line:
for this line:
Dim oCPropName As String = InputBox("Enter Custm iProperty Name", "Property Name", oParam.Name)
...to make it more interactive.
Wesley Crihfield
Message 9 of 18
WCrihfield
Another process which might be even better, would be to show you the current name of the parameter, and allow you to rename that first, then continue to expose that parameter as a custom iProperty.  That way, you now know which parameter is controlling it, and do not need to have the parameter and the custom iProperty have different names.  Just a thought.
Wesley Crihfield
Message 10 of 18
haphanthanhtam.work
Thanks so much @Curtis_Waguespack , @WCrihfield @A.Acheson
It's works
but now there is a problem I keep selecting another value but it's not on Sketch For example dimension on extrusion or other. Is there any way I can pick it up and output that value
Message 11 of 18
haphanthanhtam.work
Hi@WCrihfield  greate
Message 12 of 18
WCrihfield
Here is something that might work.  It is probably a FeatureDimension.
oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kFeatureDimensionFilter, "Select a feature dimension.")
If oObj Is Nothing OrElse (TypeOf oObj Is FeatureDimension = False) Then Exit Sub
Dim oFDim As FeatureDimension = oObj
Dim oParam As Inventor.Parameter = oFDim.Parameter
Dim sName As String = InputBox("Edit Parameter Name", "Rename Param", oParam.Name)
If sName <> "" Then Try : oParam.Name = sName : Catch : End Try
Try
Catch
End Try
Wesley Crihfield
Message 13 of 18
WCrihfield
Actually, here is a version of that last code where it will allow you to pick either type of object, then check which type you selected, then get the parameter from it.  If it is neither of those two types, it will exit the rule.  Then it lets you rename the parameter associated with what you picked.  Then it tries to expose that as a custom iProperty.
oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select a feature or sketch dimension.")
If oObj Is Nothing Then Exit Sub
Dim oParam As Inventor.Parameter = Nothing
If TypeOf oObj Is FeatureDimension Then
	oParam = oFDim.Parameter
ElseIf TypeOf oObj Is DimensionConstraint Then
	oParam = oDimConst.Parameter
Else
	Exit Sub
End If
Try
Catch
End Try
Wesley Crihfield
Message 14 of 18
haphanthanhtam.work
Hi @WCrihfield
Thanks for the help
Can i ask you 1 question. It will solve a string of my problems
I have a code used to get the minimum bounding box dimensions
Instead of showing 3 sizes I want it to show notifications
Ex:  20 x 37,895 x 50
I want it to announce that:  This value is 20 you will assign "Custom name"(I will input custom name value)
I want it to announce that:  This value is 37,895 you will assign "Custom name"(I will input custom name value)
I want it to announce that:  This value is 50 you will assign "Custom name"(I will input custom name value)
I think you can help me, you can help me
This code:
' Get the current Part document.
Dim partDoc As PartDocument = ThisDoc.Document
' Get the TransientBRep and TransientGeometry objects.
Dim transBRep As TransientBRep = ThisApplication.TransientBRep
Dim transGeom As TransientGeometry = ThisApplication.TransientGeometry
' Combine all bodies in Part into a single transient Surface Body.
Dim combinedBodies As SurfaceBody = Nothing
For Each surfBody As SurfaceBody In partDoc.ComponentDefinition.SurfaceBodies
	If combinedBodies Is Nothing Then
		combinedBodies = transBRep.Copy(surfBody)
	Else
		transBRep.DoBoolean(combinedBodies, surfBody, BooleanTypeEnum.kBooleanTypeUnion)
	End If
Next
' Get the oriented mininum range box of all bodies in Part.
' NOTE: "OrientedMinimumRangeBox" was added in Inventor 2020.3/2021.
Dim minBox As OrientedBox = combinedBodies.OrientedMinimumRangeBox
' Get length of each side of mininum range box.
Dim dir1 As Double = minBox.DirectionOne.Length
Dim dir2 As Double = minBox.DirectionTwo.Length
Dim dir3 As Double = minBox.DirectionThree.Length
' Convert lengths to document's length units.
Dim uom As UnitsOfMeasure = partDoc.UnitsOfMeasure
dir1 = uom.ConvertUnits(dir1, "cm", uom.LengthUnits)
dir2 = uom.ConvertUnits(dir2, "cm", uom.LengthUnits)
dir3 = uom.ConvertUnits(dir3, "cm", uom.LengthUnits)
' Sort lengths from smallest to largest.
Dim lengths As New List(Of Double) From {dir1, dir2, dir3 }
lengths.Sort
Dim minLength As Double = lengths(0)
Dim midLength As Double = lengths(1)
Dim maxLength As Double = lengths(2)
' Create surface to represent oriented range box...
' Create starting box with dimensions of oriented rangebox.
Dim startBox As Box = transGeom.CreateBox()
Dim boxMaxPoint As Point = transGeom.CreatePoint(minBox.DirectionOne.Length, minBox.DirectionTwo.Length, minBox.DirectionThree.Length)
startBox.Extend(boxMaxPoint)
' Create transformation matrix to move box to correct location/orientation.
Dim transMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
transMatrix.SetCoordinateSystem(minBox.CornerPoint, minBox.DirectionOne.AsUnitVector.AsVector, minBox.DirectionTwo.AsUnitVector.AsVector, minBox.DirectionThree.AsUnitVector.AsVector)
' Create surface body for the range box.
Dim minBoxSurface As SurfaceBody = ThisApplication.TransientBRep.CreateSolidBlock(startBox)
' Transform range box surface body to the correct location/orientation.
ThisApplication.TransientBRep.Transform(minBoxSurface, transMatrix)
' Display range box on screen.
Dim transac As Transaction = ThisApplication.TransactionManager.StartTransaction(partDoc, "DisplayRangeBox")
Dim cGraphics As ClientGraphics
Try
	cGraphics = partDoc.ComponentDefinition.ClientGraphicsCollection.Add("OrientedRangeBox")
	Dim surfacesNode As GraphicsNode = cGraphics.AddNode(1)
	Dim surfGraphics As SurfaceGraphics = surfacesNode.AddSurfaceGraphics(minBoxSurface)
	Dim targetAppearance As Asset
	Try
		targetAppearance = partDoc.Assets.Item("Clear - Blue")
	Catch
		Dim sourceAppearance As Asset = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9").AppearanceAssets.Item("InvGen-001-1-2") ' "Clear - Blue"
		targetAppearance = sourceAppearance.CopyTo(partDoc)
	End Try
	surfacesNode.Appearance = targetAppearance
	ThisApplication.ActiveView.Update
	' Display message with minimum rangebox size.
	MessageBox.Show("Oriented Minimum Rangebox Size: " &
	minLength.ToString("#.###") & " x " & midLength.ToString("#.###") & " x " & maxLength.ToString("#.###"),
	"Oriented Minimum Rangebox", MessageBoxButtons.OK, MessageBoxIcon.Information)
Finally
	' Remove range box from screen.
	transac.Abort
End Try
Message 15 of 18
WCrihfield
That is a pretty long and complex rule.  Since all of that geometry it creates is just transient (math only, not real), it will not have any real dimension objects or parameters that will stay after the transaction is aborted.  What would we be assigning a named to?  Do you simply want to customize the final message with a custom specified name for what each size represents, or do you want this rule to create 3 custom iProperties (one for each directional size), and write these values to those iProperties?  Or would you prefer to create 3 user parameters?  Keep in mind that if the code creates iProperties or parameters, those values will just be static, and will not actually be linked to anything real, so they will not stay accurate if something changes in the model afterwards.
Wesley Crihfield
Message 16 of 18
haphanthanhtam.work
i want this rule to create 3 custom iProperties (one for each directional size), and write these values to those iProperties. I know it won't change when the model changes
Message 17 of 18
WCrihfield
OK.  I added this section of code to your rule, just after the 3 values have been converted and sorted, but just before it starts the 'transaction', so that they will not be removed when the transaction is aborted.
'write values to custom iProperties with prompts for names
Dim sName1, sName2, sName3 As String
sName1 = InputBox("This value is " & minLength, "Assign Property Name", "")
If sName1 <> "" Then iProperties.Value("Custom", sName1) = minLength
sName2 = InputBox("This value is " & midLength, "Assign Property Name", "")
If sName2 <> "" Then iProperties.Value("Custom", sName2) = midLength
sName3 = InputBox("This value is " & maxLength, "Assign Property Name", "")
If sName3 <> "" Then iProperties.Value("Custom", sName3) = maxLength
...below is the whole thing, after that has been added in.  I hope this works the way you want it to.
	Else
	End If
Next
lengths.Sort
Try
	Try
	Catch
	End Try
Finally
	transac.Abort
End Try
Wesley Crihfield
Message 18 of 18
haphanthanhtam.work
Hi @WCrihfield
I try it in a part
	Else
	End If
Next
lengths.Sort
Try
	Try
	Catch
	End Try
Dim oCPropName As String = InputBox("Enter Custm iProperty Name", "Property Name", midLength)
Try
Catch
End Try
End If
Finally
	transac.Abort
End Try
it's going wrong from here You can export its value to iproperties like your code worked.
Try
Catch
End Try
End If
