Get attributes values from Sketched Symbol
martinhoos
Message 1 of 8
martinhoos
Hi all,
i found a code that gives me back the result of "Index Nummer" - the code was written by Curtis Waguespack.
The question is: How can i get the highest value of the "Index Nummer"?  The syntax of the field is:  a00, a01, a02, a03 .... a99
The code shouldt look on all sheets.
Dim oDoc  As Document
oDoc = ThisApplication.ActiveDocument
'find the symbol by name
For Each oSymbol In oDoc.ActiveSheet.SketchedSymbols
	If oSymbol.Name = "Aenderungs-Index-Zeile" Then
		'find the text box by name/label
		For Each oTextBox In oSymbol.Definition.Sketch.Textboxes
			If oTextBox.Text = "Index Nummer"
				oString = oSymbol.GetResultText(oTextBox)
				'write value to iproperty
				iProperties.Value("Status", "Eng. Approved By") = oString
				'display value to user
				MessageBox.Show(oString, "iLogic")
			End If
		Next
	End If
Next
Thanks in advance
Regards
Martin
Replies (7)
Message 2 of 8
HermJan.Otterman
Hello Martin,
I altered your code a little
try this:
 Dim oDrawDoc As DrawingDocument
        oDrawDoc = ThisApplication.ActiveDocument
        Dim oSheet As Sheet = Nothing
        Dim HighestNumber As Integer = 0
        For Each oSheet In oDrawDoc.Sheets
            For Each oSymbol In oSheet.SketchedSymbols
                        If oTextBox.Text = "Index Nummer" Then
                            Dim oString As String = oSymbol.GetResultText(oTextBox)
                            'split the string, get the last two characters
                            Dim Number As Integer = Strings.Right(oString, 2)
                            If Number > HighestNumber Then HighestNumber = Number
                        End If
                    Next
                End If
            Next
        Next
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 8
martinhoos
Hello HermJan,
thank you for your reply. There is only one Problem, if there is a sketched symbol on sheet one with a01 and a sketched symbol on sheet two with a02, your code writes: a01
Regards Martin
Message 4 of 8
HermJan.Otterman
oDrawDoc = _inventorApplication.ActiveDocument 'ThisApplication.ActiveDocument
End If
Next
End If
Next
Next
iProperties.Value("Status", "Eng. Approved By") = HighestNumber
MessageBox.Show(HighestNumber, "iLogic")
Herm Jan
Message 5 of 8
HermJan.Otterman
I hope that it works now.
had to give back the highestNumber, not ostring
Herm Jan
Message 6 of 8
HermJan.Otterman
change the second line... the green code is correct...
it should say:
Herm Jan
Message 7 of 8
martinhoos
Hello HermJan,
thank you very much - your code works!
Regards
Martin
Message 8 of 8
martinhoos
Hello Jan,
can you help me again? I told you that your code runs... thats right - but in the meantime we found out, that we have old drawings that have a1 or a2 ....a9 included. in that case the code didnt work.
We changed our syntax from a1 to a01 and so on - that means that a1 is the same like a01
Is it possible for you to modify the code for that case?
thanks in advance
Regards
Martin
