Get answer from a messagebox - external rule
tuliobarata
tuliobarata
Hi all again,
In that NOTES form that im creating, in some part i ask to the user if he wants  to erase all the data from the textboxes, using this code.
But i have 2 problems.
with buttons OK and cancel or Yes and NO, if I click in any button, the  rule runs... how could i get the users answer and run this rule just if the user choose YES or OK ?
And to erase the parameters, it takes +- 4seconds, i guess its too long! Why is that ? how could I improve this time ?
 obs, im using this code inside a EXTERNAL RULE thats called in a GLOBAL FORM.
i = MessageBox.Show("Desenja mesmo apagar as notas ?" & vbCrLf & vbCrLf & "Obs.: Caso a opção ""0 - Notas em branco"" NÂO esteja" & vbCrLf & "selecionada, as notas típicas serão mantidas!" , "Confirmação:",MessageBoxButtons.OKCancel,MessageBoxIcon.Exclamation)
If Not i Then
Parameter("Nota1_ID1") = ""
Parameter("Nota2_ID1") = ""
Parameter("Nota3_ID1") = ""
Parameter("Nota4_ID1") = ""
Parameter("Nota5_ID1") = ""
Parameter("Nota6_ID1") = ""
Parameter("Nota7_ID1") = ""
Parameter("Nota8_ID1") = ""
Parameter("Nota9_ID1") = ""
Parameter("Nota10_ID1") = ""
Parameter("Nota11_ID1") = ""
Parameter("Nota12_ID1") = ""
Parameter("Nota1_ID2") = ""
Parameter("Nota2_ID2") = ""
Parameter("Nota3_ID2") = ""
Parameter("Nota4_ID2") = ""
Parameter("Nota5_ID2") = ""
Parameter("Nota6_ID2") = ""
Parameter("Nota7_ID2") = ""
Parameter("Nota8_ID2") = ""
Parameter("Nota9_ID2") = ""
Parameter("Nota10_ID2") = ""
Parameter("Nota11_ID2") = ""
Parameter("Nota12_ID2") = ""
End If
Thanks again!
Túlio Barata
IV 2013
xiaodong_liang
Autodesk Support
Autodesk Support
ilogic is based on VB.NET. So you can get the enum of MessageBox.Show in MSDN:
 // Summary:
    //     Specifies identifiers to indicate the return value of a dialog box.
    [ComVisible(true)]
    public enum DialogResult
        // Summary:
        //     Nothing is returned from the dialog box. This means that the modal dialog
        //     continues running.
        None = 0,
        // Summary:
        //     The dialog box return value is OK (usually sent from a button labeled OK).
        OK = 1,
        // Summary:
        //     The dialog box return value is Cancel (usually sent from a button labeled
        //     Cancel).
        Cancel = 2,
        // Summary:
        //     The dialog box return value is Abort (usually sent from a button labeled
        //     Abort).
        Abort = 3,
        // Summary:
        //     The dialog box return value is Retry (usually sent from a button labeled
        //     Retry).
        Retry = 4,
        // Summary:
        //     The dialog box return value is Ignore (usually sent from a button labeled
        //     Ignore).
        Ignore = 5,
        // Summary:
        //     The dialog box return value is Yes (usually sent from a button labeled Yes).
        Yes = 6,
        // Summary:
        //     The dialog box return value is No (usually sent from a button labeled No).
        No = 7,
  so, in this case you can know  i = 1 means the user clicks OK.
As to performance issue, without a sample, it is hard to give a comment. You will need to provide a reproducible demo.
