get all referencedocument without opening assembly
skyngu
skyngu
hi all,
in inventor VBA, is it possible to get all reference documents without opening an assembly file in inventor?
this is i am using right now,
Dim oAssyDoc As AssemblyDocument
Set oAssyDoc = oInvApp.Documents.Open(sAssyPath)
oAssyDoc.Update
Dim oAllRefParts As DocumentsEnumerator
 If Check1 = True Then
Set oAllRefParts = oAssyDoc.ReferencedDocuments
Else
Set oAllRefParts = oAssyDoc.AllReferencedDocuments End If
thanks
Autodesk Inventor Professional 2019
Mike.Wohletz
The file will need to be opened in something to get this, if you don't have it open then you can use the Apprentice Server to get the info needed.
barbara.han
If you just want to use VBA, you can open the file as invisible. See the following demo:
Sub OpenAssembyInvisible()
    Dim assDoc As AssemblyDocument
    Set assDoc = ThisApplication.Documents.Open("c:\temp\assembly1.iam", False)
    On Error Resume Next
    Dim refDes As FileDescriptor
    For Each refDes In assDoc.File.ReferencedFileDescriptors
        Debug.Print refDes.FullFileName
        If Not refDes.ReferencedFile Is Nothing Then
            If Err Then
                ' refDes.ReferencedFile may be exception
                Err.Clear
            Else
                Dim refDoc As Document
                Set refDoc = refDes.ReferencedFile.AvailableDocuments(1)
                ' Do something here...
                Debug.Print refDoc.PropertySets.Count
            End If
        End If
    Next
    assDoc.Close (True)
End Sub
You may notice that I used AssemblyDocument.File.ReferencedFileDescriptors to iterate down the assembly structure, instead of AssemblyDocument.ReferencedDocumentDescriptors. This is due to some referenced files (e.g. substitue part) being not open in memory for sure. File.ReferencedFileDescriptors can find all files. Hope this helps.
Barbara Han
Developer Technical Services
Autodesk Developer Network
skyngu
thanks for the tip.
acturally, i try to print out all reference parts. I will see either server or open in "false" is faster.
barbara.han
The real issue that affects the speed/performance lays on the file openning. Iterating the assembly structure is fast engough. Using apprentice server or Inventor may not be that different on the speed.
If you want to use apprentice, maybe you can refer to my sample application posted to Autodesk Labs:
Plugin of the Month Catalog on Autodesk Labs -->Inventor category -> Hierarchy Clone for Inventor. Good luck!
Barbara Han
skyngu
thanks again.
so that is possible to save a drawing as pdf without opening the drawing.  I tried to open drawing in "false". it gives me error. guess using apprentic server will do it.
brendan.henderson
If you are just after a method to print all of the refeenced IDW's from an assembly then head over to the below page for a macro a friend gave me. Read the posts to get the caveats for use.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Printing-all-drawings-of-an-assembly-f...
Brendan Henderson
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
