Get a Set of Edges used for creation of Fillet feature
Maxim-CADman77
Advisor Advisor
Message 1 of 9
Maxim-CADman77
I wonder if it possible to get a set of Edges picked by user for (simple) Fillet creation?
Please vote for Inventor-Idea Text Search within Option Names
Replies (8)
Message 2 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
Message 3 of 9
Maxim-CADman77
Thank you for attempt to help but  those samples don't suit my situation (none of them describes getting edges ... but rather setting )
Message 4 of 9
Maxim-CADman77
I still need some help with this...
Message 5 of 9
Maxim-CADman77
Ok. I see nobody knows the answer to the main question of the thread ..  but if it possible at least determine the type of the given Fillet (All Rounds/Complex/Simple)?
Message 6 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@Maxim-CADman77,
After creating fillet feature, used edges are converted to face.
Public Sub fillet_edges()
    Dim oDOc As PartDocument
    Set oDOc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDOc.ComponentDefinition
    Dim oFillet As FilletFeature
    Set oFillet = oDef.Features.FilletFeatures.Item(1)
    Debug.Print oFillet.Faces.Count
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 9
Maxim-CADman77
Ok. Now I can at least choose the first edge of the fillet
MsgBox (ThisDoc.Document.ComponentDefinition.Features.FilletFeatures.Item(1).Faces.Item(1).Edges.Count)
oEdge=ThisDoc.Document.ComponentDefinition.Features.FilletFeatures.Item(1).Faces.Item(1).Edges.Item(1)
But my final goal is re-creation of the issued element I did it for revolutions and extrusions and now I'm working on fixing fillets (the root thread is - https://forums.autodesk.com/t5/inventor-customization/re-create-an-element/m-p/7986267#M84066)
How can I "backup" (copy) this edge in order I can use it after suppreesing/deleting the initial fillet?
Message 8 of 9
cencinaNB2ET
I need to access the edge collection I used to create a constant radius edge fillet.. but I cant find any examples. If I search through faces then edges I get more edges and not the original used to create it.
Message 9 of 9
JelteDeJong
you can try this rule. When you run the rule it will ask you to select a fillet. if you do it will set the and of the part before the fillet and then select the edges used by the fillet
Dim ff As FilletFeature = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "Select fillet")
Dim doc As PartDocument = ThisDoc.Document
ff.SetEndOfPart(True)
doc.SelectSet.Clear()
For i = 1 To ff.FilletDefinition.EdgeSetCount
    For Each edge As Edge In ff.FilletDefinition.EdgeSetItem(i).Edges
        doc.SelectSet.Select(Edge)
    Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
