Geometry Intent + Scaled Views + Wonky Leaders
MechMachineMan
Advisor Advisor
MechMachineMan
I am getting this result when using .AddWithLeaders with a view that has been scaled (1/2"=1"). It seems that the geometry can't communication between the 2; but if I try modifying the geometry intent points by a scale factor, it always throws an error.
The basics of the program is:
Dim oDLine As DrawingCurveSegment
Dim oDwgDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oView As DrawingView
Dim oSketch As DrawingSketch
Dim oLine As SketchLine
Dim oSecLine As SketchLine
Dim angle As Double
Dim tailangle As Double
oDLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select the LINE")
oSP = oDLine.StartPoint
oEP = oDLine.EndPoint
Dim oV1 As Vector2d
Dim oV2 As Vector2d
If oEP.Y > oSP.Y
	oV1 = ThisApplication.TransientGeometry.CreateVector2d(oEP.X - oSP.X, oEP.Y - oSP.Y)
	oV2 = ThisApplication.TransientGeometry.CreateVector2d(1, 0)
Else
	oV1 = ThisApplication.TransientGeometry.CreateVector2d(oSP.X - oEP.X, oSP.Y - oEP.Y)
angle = oV2.AngleTo(oV1)
For Each oView In oDwgDoc.ActiveSheet.DrawingViews
	For Each oSketch In oView.Sketches
		For Each oLine In oSketch.SketchLines
			If Math.Abs(Math.Round(oView.Scale*(oLine.StartSketchPoint.Geometry.X - oLine.EndSketchPoint.Geometry.X),3)) = Math.Abs(Math.Round((oSP.X - oEP.X),3)) And _
				Math.Abs(Math.Round(oView.Scale*(oLine.StartSketchPoint.Geometry.Y - oLine.EndSketchPoint.Geometry.Y),3)) = Math.Abs(Math.Round((oSP.Y - oEP.Y),3))
				oSecLine = oLine
		Next
	Next
Next
Dim oTG As TransientGeometry
Dim oGeometryIntent1 As GeometryIntent
Dim oLeaderPoints1 As ObjectCollection
Dim oGeometryIntent2 As GeometryIntent
Dim oLeaderPoints2 As ObjectCollection
   oTG = ThisApplication.TransientGeometry
    oLeaderPoints1 = ThisApplication.TransientObjects.CreateObjectCollection
    oLeaderPoints1.Add(oSP)
    oGeometryIntent1 = oDwgDoc.ActiveSheet.CreateGeometryIntent(oSecLine, oSecLine.StartSketchPoint.Geometry)
    oLeaderPoints1.Add(oGeometryIntent1)
	oLeaderPoints2 = ThisApplication.TransientObjects.CreateObjectCollection
    oLeaderPoints2.Add(oEP)
    oGeometryIntent2 = oDwgDoc.ActiveSheet.CreateGeometryIntent(oSecLine, oSecLine.EndSketchPoint.Geometry)
    oLeaderPoints2.Add(oGeometryIntent2)
Any help is greatly appreciated! Thanks.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
adam.nagy
Autodesk Support
Autodesk Support
Hi Justin,
Is all OK when adding the leader through the UI?
If so, then as a start you could create one in the UI and then investigate in VBA what properties it has:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Cheers,
Adam Nagy
Autodesk Platform Services
MechMachineMan
Hi Adam!
Sorry, this is outdated. I figured it out. I was adding 2 sets of points to
the AddWithLeader method and it was throwing it off. Using only 1 set of
points with the geometry intent worked for my needs much better. I was
mistaken in thinking I needed points for each leader node even if they were
the same point in space.
Thanks for the response though!
Justin K
adam.nagy
Autodesk Support
Autodesk Support
Glad it's working now 🙂
Adam Nagy
MechMachineMan
Sorry, my previous reply was a little off; apparently it just needed the geometry intent. Here is the relevant chunk of code:
				oSecLine = oLine
				oCP = oTG.CreatePoint2d(oSketch.Parent.Position.X, oSketch.Parent.Position.Y)
				oSecSP = oTG.CreatePoint2d(oCP.X +oSecLine.StartSketchPoint.Geometry.X*oView.Scale, oCP.Y + oSecLine.StartSketchPoint.Geometry.Y*oView.Scale)
				oSecEP = oTG.CreatePoint2d(oCP.X +oSecLine.EndSketchPoint.Geometry.X*oView.Scale, oCP.Y + oSecLine.EndSketchPoint.Geometry.Y*oView.Scale)
		Next
	Next
Next
oGeometryIntent1 = oDwgDoc.ActiveSheet.CreateGeometryIntent(oSecLine, oSecSP)
oGeometryIntent2 = oDwgDoc.ActiveSheet.CreateGeometryIntent(oSecLine, oSecEP)
oS1 = oDwgDoc.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD1,oLeaderPoints1,angle,1,,False,True)
oS1.LeaderVisible = False
oS2 = oDwgDoc.ActiveSheet.SketchedSymbols.AddWithLeader(oSSD,oLeaderPoints2,angle1,1,PromptStrings,False,True)
oS2.LeaderVisible = False
Justin K
