G2 Fillet API Call?
G2 Fillet API Call?
dylanTEV9W
G2 Fillet API Call?
dylanTEV9W
Hello everyone,
I'm wondering if there's a way to create a G2 fillet via an API call? I haven't figured it out yet myself an I'm hoping someone on here knows how.
HideoYamada
Hello
It seems people include me couldn't find the solution, thus there would be no way.
Why don't you post on Inventor Ideas?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
dylanTEV9W
Then you'll be happy to know I stumbled upon a solution early this morning.
Here is my solution it works just fine although it seems rather strange that this is how a fillets continuity has to be set:
private void CreateG2Fillet(PartDocument part_doc, TransientObjects trans_objects)
FilletFeatures fillets = device_part_doc.ComponentDefinition.Features.FilletFeatures; //Get the fillet features object
FilletDefinition = fillet_def = fillets.CreateFilletDefinition(); //Create a new fillet definition
EdgeCollection fillet_edges = trans_objects.CreateEdgeCollection();
fillet_edges = RetrieveEdges(); //Get the edges to fillet through whatever method you prefer / need
//Create a Constant radius edge set from the Fillet definition
FilletConstantRadiusEdgeSet fillet_edge_set = fillet_def.AddConstantRadiusEdgeSet(fillet_edges, fillet_radius);
//Set the continnuity type to curvature continuity using the Continuity Type enumerator.
fillet_edge_set.ContinuityType = ContinuityTypeEnum.kCurvatureContinuity;
fillets.Add(fillet_def); //Create a new fillet using the fillet definition we just created
//Update the part doc to process adding the fillet, this call could also be made from the block of code that calls
//this function.
part_doc.Update();
