FRONT AND FLAT PATTERNS IN SEPARATE SHEETS
formobalaji
Message 1 of 1
formobalaji
I HAVE A CODE THAT CREATS ALL FLAT PATTERNS IN OF SM IN ASSEMBLY IN EACH SHEETS , I NEED THE FRONT AND SIDE VIEW ALSO ALONG WITH FLATPATTERN
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly must be active for this rule to work. Exiting.", vbCritical, "iLogic")
		Exit Sub
	End If
	Dim oADoc As AssemblyDocument = ThisDoc.Document
	Dim sAsmPath As String = System.IO.Path.GetDirectoryName(oADoc.FullFileName)
	Dim sAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oADoc.FullFileName)
	Dim sFolder As String = sAsmPath & "\" & sAsmName & " DXF Drawings\"
	If System.IO.Directory.Exists(sFolder) = False Then
		Try : System.IO.Directory.CreateDirectory(sFolder)
		Catch : Logger.Error("Could not create directory.") : End Try
	End If
	Dim oRefDocs As DocumentsEnumerator = oADoc.AllReferencedDocuments
	If oRefDocs.Count = 0 Then Exit Sub
	Dim sTemplate As String = "C:\Users\fcpl017\Desktop\standard.idw"
	Dim oDDoc As DrawingDocument = Nothing
	oDDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, sTemplate, False)
	Dim oSheets As Inventor.Sheets = oDDoc.Sheets
	Dim oFirstSheet As Inventor.Sheet = oDDoc.ActiveSheet
	For Each oRefDoc As Document In oRefDocs
		'if this referenced document is not a Sheet Metal part, then skip to next one
		If oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
		'Dim COUNT_BEND As Integer = oRefDoc.PropertySets.Item(4).Item("BEND_COUNT").Value
		'If COUNT_BEND < 1 Then Continue For
		Dim sPN As String = oRefDoc.PropertySets.Item(3).Item("Part Number").Value
						'Dim sCustomPropName As String = "PROJECT PARTNUMBER"
		'Dim oCustomSet As Inventor.PropertySet = oRefDoc.PropertySets.Item(4)
			'oCustomProp = oCustomSet.Item(sCustomPropName)
	'oFileName = oCustomProp.Value
		Dim oSheet As Inventor.Sheet = Nothing
		If oFirstSheet.DrawingViews.Count = 0 Then
			oSheet = oFirstSheet
		Else
			oSheet = oSheets.Add()
		End If
		Try
    oSheet.Name = sPN
	'oSheet.Name = oFileName
Catch
End Try
Dim oPos As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width / 2, oSheet.Height / 2)
Dim dScale As Double = 1 '<<<must compare model size to sheet size for accurate value>>>
Dim oVO As ViewOrientationTypeEnum = ViewOrientationTypeEnum.kFlatPivot180ViewOrientation
Dim oDVS As DrawingViewStyleEnum = DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Add("SheetMetalFoldedModel", False)
oSheet.DrawingViews.AddBaseView(oRefDoc, oPos, dScale, oVO, oDVS, , , oOptions)
	Next
	oDDoc.SaveAs(sFolder & "FlatPatterns.idw", False)
	MsgBox("Exported All FlatPatterns To Drawing Views.", vbInformation, "iLogic")
End Sub"
Replies (0)
