- Mute
- Permalink
- Report
Hello guys,
I've written this small function and I'd like to transpose it to vb.net.
'm planning to move all my functions to vb.net and want to use this one as a first howto.
A link to a howto would also be great! Where could I find some howto?
Public Sub WP_Off() 'Visible Work Plan in parts OFF Dim invDoc As Document Set invDoc = ThisApplication.ActiveDocument If invDoc.DocumentType = kPartDocumentObject Then Dim pcd As PartComponentDefinition Set pcd = invDoc.ComponentDefinition Dim wpls As WorkPlanes Set wpls = pcd.WorkPlanes Dim owas As WorkAxes Set owas = pcd.WorkAxes Dim owpos As WorkPoints Set owpos = pcd.WorkPoints Dim owa As WorkAxis Dim owp As WorkPlane Dim owpo As WorkPoint For Each owp In wpls If owp.Visible = True Then owp.Visible = False End If Next For Each owa In owas If owa.Visible = True Then owa.Visible = False End If Next For Each owpo In owpos If owpo.Visible = True Then owpo.Visible = False End If Next Else: Exit Sub End If End Sub
