Freeform Object Support in API
I am trying to convert an imported Mesh to a Freeform object and manipulate it using the Edit Form command, all using the Inventor API. However, I do not see any options to create a new Freeform object or use Freeform commands in the API. Am I missing something? If this isn't possible to do in Inventor, could I do it in something with a more robust API like Fusion 360?
Mohamed_Rafick
I also have the same question as yours. Did you found any alternate solution for that?
