FREE SAVE DXF MACRO FOR YOUR HELP!
In giving away this very handy macro I'm asking for some help to improve it. I'm not a programmer and I think the person who wrote this has passed on. 😞
Firstly what does the macro do? It creates a DXF file of the current sheetmetal document flat pattern. Basically the same as Save Copy As in the part Flat Pattern environment. Also it creates a few custom iProperties for the part cutting length (InnerPerimeters, OuterPerimeter and TotalPerimeters). These are handy for laser/plasma cutters to base pricing on.
What do I want? I need some help making the saved (output) DXF file name the same as the iProperty Project (on the Project tab of iProperties). Currently I have the iProperty Project = <Part Number>-<Revision Number>.dxf and I need this to be the saved DXF file name. That's all! Seems simple but I can't figure it out.
Any takers?
Sub FP2DXF()
Dim oPartDoc As Document
Set oPartDoc = ThisApplication.ActiveDocument
' The Active document must be a part
If oPartDoc.DocumentType <> kPartDocumentObject Then
    MsgBox "The Active document must be a 'Part'"
    Exit Sub
End If
' The Active document must be a Sheet metal Part
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
    MsgBox "The Active document must be a 'Sheet Metal Part'"
    Exit Sub
End If
' Check if part needs to be saved
If oPartDoc.Dirty = True Then
    MsgBox "Please save this Sheet metal part"
    Exit Sub
End If
Dim oFlatPattern As FlatPattern
Set oFlatPattern = oPartDoc.ComponentDefinition.FlatPattern
' There must be a flat pattern
If oFlatPattern Is Nothing Then
    MsgBox "Please create the flat pattern"
    Exit Sub
End If
Dim oDXFfileNAME As String
oDXFfileNAME = Left(oPartDoc.FullFileName, Len(oPartDoc.FullFileName) - 4) & ".DXF"
Dim oDataIO As DataIO
Set oDataIO = oPartDoc.ComponentDefinition.DataIO
Dim sOut As String
    sOut = "FLAT PATTERN DXF?AcadVersion=2000" _
        + "&OuterProfileLayer=OUTER_PROF&OuterProfileLayerColor=255;0;0" _
        + "&InteriorProfilesLayer=INNER_PROFS&InteriorProfilesLayerColor=0;255;255" _
        + "&FeatureProfileLayer=FEATURE&FeatureProfileLayerColor=0;0;255" _
        + "&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS"
        '+ "&BendUpLayer=BEND_UP&BendUpLayerColor=255;0;255&BendUpLayerLineType=37634" _
        '+ "&BendDownLayer=BEND_DOWN&BendDownLayerColor=255;255;0&BendDownLayerLineType=37634" _
        '+ "&SimplifySplines=True&MergeProfilesIntoPolyline=True" _
        '+ "&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS"
   oDataIO.WriteDataToFile sOut, oDXFfileNAME
    ' Check for a non-part document
        Exit Sub
    End If
        MsgBox "The 'Part' must be a Sheet Metal Part"
        Exit Sub
    End If
    Dim oSheetMetalCompDef As SheetMetalComponentDefinition
    Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
    ' Get the cut length
    Dim oFace As Face
    Set oFace = oSheetMetalCompDef.FlatPattern.TopFace
    ' Find the outer loop.
    Dim dOuterLength As Double
    dOuterLength = 0
    Dim oLoop As EdgeLoop
    For Each oLoop In oFace.EdgeLoops
        If oLoop.IsOuterEdgeLoop Then
            Dim oEdge As Edge
            For Each oEdge In oLoop.Edges
                ' Get the length of the current edge.
                Dim dMin As Double, dMax As Double
                Call oEdge.Evaluator.GetParamExtents(dMin, dMax)
                Dim dLength As Double
                Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength)
                dOuterLength = dOuterLength + dLength
            Next
            'MsgBox "Outer Loop is " & FormatNumber(dOuterLength, 1)
            Exit For
        End If
    Next
    ' Iterate through the inner loops.
    Dim iLoopCount As Long
    iLoopCount = 0
    Dim dTotalLength As Double
        Dim dLoopLength As Double
        dLoopLength = 0
        If Not oLoop.IsOuterEdgeLoop Then
                dLoopLength = dLoopLength + dLength
            Next
            ' Add this loop to the total length.
            dTotalLength = dTotalLength + dLoopLength
            'MsgBox "Inner Loops are " & FormatNumber(dTotalLength, 1)
        End If
    Next
    Dim oUom As UnitsOfMeasure
    Set oUom = oPartDoc.UnitsOfMeasure
    outerCutlength = oUom.GetStringFromValue(dOuterLength, kMillimeterLengthUnits)
    innerCutlength = oUom.GetStringFromValue(dTotalLength, kMillimeterLengthUnits)
    TotalCutLength = oUom.GetStringFromValue(dTotalLength + dOuterLength, kMillimeterLengthUnits)
    'Write data to properties, creating or updating (if property exists)
    Dim oCustomPropSet As PropertySet
    Set oCustomPropSet = oPartDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
    On Error Resume Next
    oCustomPropSet.Item("OuterPerimeter").Value = outerCutlength
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(outerCutlength, "OuterPerimeter")
    End If
    oCustomPropSet.Item("InnerPerimeters").Value = innerCutlength
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(innerCutlength, "InnerPerimeters")
    End If
    oCustomPropSet.Item("TotalPerimeter").Value = TotalCutLength
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(TotalCutLength, "TotalPerimeter")
    End If
End Sub
matt_jlt
Hi Brendan, this should hopefully do the trick.
Replace the following:
with new code below
Dim strProject As String
strProject = oPartDoc.PropertySets("Design Tracking Properties").Item("Project").Value
Dim strPath As String
strPath = Left(oPartDoc.FullFileName, InStrRev(oPartDoc.FullFileName, "\"))
oDXFfileNAME = strPath & strProject & ".dxf"
Regards, Matt.
If this is correct please mark it as the answer
Heaps of thanks to you Matt. It works great. Smiley Happy
