Frame Generator Part Used for Skeleton
KWarrenCA
KWarrenCA
We use a single part with sketches to run frames and normally turn the part to phantom so that it doesn't show up in the BOM. I'm looking for a way to when I run my iLogic to find that referenced part and change the BOM structure to phantom. I currently have the below code but that only changes the refence skeleton in the frame generator. We always use 0000 at the end of the part for the reference part so I was thinking about using the file name to check if that is the case.
If oPDoc.DocumentInterests.HasInterest("SkeletonDoc") Then
				oPDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
C_Haines_ENG
See if this works.
Sub Main
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	For Each oOcc As ComponentOccurrence In oAsm.ComponentDefinition.Occurrences.AllLeafOccurrences
        If Split(oOcc.Name, ":")(0).EndsWith("0000") Then oOcc.Definition.BOMStructure = kPhantomBOMStructure
	Next
End Sub
