Frame Generator Demote populate metadata not working
basautomationservices
Hi all,
I'm trying to populate the fields of the demote dialog when demoting a frame generator beam.
Somehow the fields just go back to the defaults when the popup comes. Does anyone know if I am doing something wrong or if maybe frame generator just overrides the fields?
When just clicking OK the displayname is edited correctly.
Code used:
                var savingFolder = new SavingFolder(assembly.FullFileName, projectFolder);
                var indexNumber = new IndexNumber(savingFolder.DirectoryName);
                var basename = $"SA{indexNumber.Text}-A-1";
                var assyname = $"{basename}.iam";
                var fullfilename = $"{savingFolder.DirectoryName}/{assyname}";
                var metadata = FileMetadataObjects.GetEnumerator().ToEnumerable<FileMetadata>().FirstOrDefault();
                metadata.DisplayNameOverridden = true;
                metadata.DisplayName = basename;
                metadata.FileNameOverridden = true;
                metadata.FileName = assyname;
                metadata.TemplateFileName = Core.Properties.Settings.Default.TemplateFilename;
                var properties = metadata.FileProperties;
                metadata.FullFileName = fullfilename;
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
For the regular demote command everything is working fine by the way.
I found part of the problem. I was in the wrong assembly context, I should have been using ActiveEditDocument in this case.
However, the template is still not working for the Frame Generator demote command.
