Create drawing dimensions using work features within subcomponent
mat_hijs
mat_hijs
I'm trying to automate creating some dimensions for my drawings. I got to the point where I can dimension a part using the workplanes  in that part. Now I'm trying to get to the next step which is placing these same dimensions when this part is placed in an assembly. I think I'm almost there, but I can't get the last step, actually creating the dimension, to work. Could anyone help me out on this one?
Here's my code:
Dim oDoc As DrawingDocument
	oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
	oSheet = oDoc.ActiveSheet
Dim oDrawingViews As DrawingViews
Dim oDrawingView As DrawingView
	oDrawingView = ActiveSheet.View("VIEW1").View
Dim oModelAsm As AssemblyDocument
	oModelAsm = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oModelAsmCompDef As AssemblyComponentDefinition
	oModelAsmCompDef = oModelAsm.ComponentDefinition
Dim oModelPart As ComponentOccurrence
	oModelPart = oModelAsmCompDef.Occurrences.ItemByName("Profiel")
Dim oModelPartDoc As PartDocument
	oModelPartDoc = oModelPart.Definition.Document
Dim oModelPartCompDef As PartComponentDefinition
	oModelPartCompDef = oModelPartDoc.ComponentDefinition
Dim oOnderkant As WorkPlane
	oOnderkant = oModelPartCompDef.WorkPlanes.Item("WPL_Onderkant")
Dim oBovenkant As WorkPlane
	oBovenkant = oModelPartCompDef.WorkPlanes.Item("WPL_Bovenkant")
Dim oOnderkantIntent As GeometryIntent
	oOnderkantIntent = oSheet.CreateGeometryIntent(oOnderkant)
Dim oBovenkantIntent As GeometryIntent
	oBovenkantIntent = oSheet.CreateGeometryIntent(oBovenkant)
Dim oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions
Dim oPointX As Double
	oPointX = -2
Dim oPointY As Double
	oPointY = 0
Dim oPoint As Point2d
	oPoint = ThisServer.TransientGeometry.CreatePoint2d(oPointX, oPointY)
MsgBox("This is where I stop working.")
Dim oLinearDimLengte = oGeneralDims.AddLinear(oPoint, oOnderkantIntent, oBovenkantIntent)
Ralf_Krieg
Hello
The workplanes of your part are represented by a workplaneproxy object in assembly context. So you first have to create this proxy objects to "walk" in the right context.
The included workplanes/workplaneproxys are displayed as centerlines on sheet. So you need to create a geometryintent for these centerlines to attach your dimension to.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oDrawingView As DrawingView= ActiveSheet.View("VIEW1").View
Dim oModelAsm As AssemblyDocument = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oModelAsmCompDef As AssemblyComponentDefinition = oModelAsm.ComponentDefinition
Dim oModelPart As ComponentOccurrence = oModelAsmCompDef.Occurrences.ItemByName("Profiel")
Dim oModelPartDoc As PartDocument = oModelPart.Definition.Document
Dim oModelPartCompDef As PartComponentDefinition = oModelPartDoc.ComponentDefinition
Dim oOnderkant As WorkPlane = oModelPartCompDef.WorkPlanes.Item("WPL_Onderkant")
Dim oBovenkant As WorkPlane = oModelPartCompDef.WorkPlanes.Item("WPL_Bovenkant")
Dim oOnderkantProxy As WorkPlaneProxy
Call oModelPart.CreateGeometryProxy(oOnderkant, oOnderkantProxy)
Dim oBovenkantProxy As WorkPlaneProxy
Call oModelPart.CreateGeometryProxy(oBovenkant, oBovenkantProxy)
Dim oCenterline As Centerline
For Each oCenterline In oSheet.Centerlines
    If oCenterline.ModelWorkFeature Is oOnderkantProxy Then
        oOnderkantIntent = oSheet.CreateGeometryIntent(oCenterline)
    ElseIf oCenterline.ModelWorkFeature Is oBovenkantProxy Then
        oBovenkantIntent = oSheet.CreateGeometryIntent(oCenterline)
Next
Dim oPointX As Double = -2
Dim oPointY As Double = 0
Dim oPoint As Point2d = ThisServer.TransientGeometry.CreatePoint2d(oPointX, oPointY)
'MsgBox("This is where I stop working.")
Dim oLinearDimLengte = oGeneralDims.AddLinear(oPoint, oOnderkantIntent, oBovenkantIntent, DimensionTypeEnum.kAlignedDimensionType, True)
R. Krieg
RKW Solutions
www.rkw-solutions.com
JelteDeJong
I think you need to use WorkPlaneProxy's in stead of WorkPlanes when you create intents from a assembly. I could not test this code but i expect that it will work:
Dim oSheet As Sheet
' Create proxy work planes
Dim oOnderkantProxy As WorkPlaneProxy = Nothing
Dim oBovenkantProxy As WorkPlaneProxy = Nothing
' use the proxy work planes instead of the original workplanes
oOnderkantIntent = oSheet.CreateGeometryIntent(oOnderkantProxy)
oBovenkantIntent = oSheet.CreateGeometryIntent(oBovenkantProxy)
oPointX = -2
oPointY = 0
On a side note if you are using Inventor 2021 or later there are build in functions that do a great job in creating dimensions for parts. For Assemblies those functions do not work but in my blog i write how you can create your own functions.
Jelte de Jong
Blog: hjalte.nl - github.com
mat_hijs
I had some issues running your code, but after a while I found that the workplanes have to be included in the view first, after I did this it worked perfectly. I added a couple of lines that include the workplanes and then makes the centerlines invisible. After that I transformed the whole thing into a function so I can call the function, enter 2 workplanes and leave the rest for the function to figure out. Next up: automating the creation of breaks 😄
Thanks for your help!
