09:24 AM
- Mute
- Permalink
- Report
I'm trying to generate a base assembly using iLogic with frame generator components. The problem I'm running into is that iLogic is not suppressing some of the components. I have 5 frame sizes that either require a 2" square tube frame or a 3" square tube frame. If there is a way to cut down on quiet a bit of the logic it would be greatly appreciated as well.
Attached is the assembly that I'm working in. There should be the iLogic as well as the form for the different sizes.
Sam
