- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to automate an email we have to send upon job completion, I've started with the Curtis's illogic from . I also found info HERE. I'm almost there, but I can't seem to find the correct format to edit the text size/Font/Bolding required. The email should look like:
CRITICAL ACTION: Replace old revisions on the shop floor & at vendor with the new revisions and destroy the old revisions.
WORK ORDER #: XXXXX/X Customer / Description
DESCRIPTION OF CHANGES:
This e-mail is to inform you that the drawing(s) listed below are approved:
Drawing/Part Number | Rev | Description | Status |
| HIGH |
Status / Required Action:
LOW / No active quote(s) or current need. (To: )
MED / Need to quote or generate purchase order. (To: )
HIGH / There is a work order in Progress. Destroy all copies of obsolete drawings and replace with latest revision. (To: )
SALES / This is a sales drawing. (To: )
All drawing files referenced in this e-mail have been loaded onto network folder: \\Server\engineering\COMMON\Parts Folder RELEASED PDFs
Current Ilogic:
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName) Dim oOApp Dim oOMail oOApp = CreateObject("Outlook.Application") oOMail = oOApp.CreateItem(olMailItem) Dim oWorkOrder As String Dim oCustomer As String Dim MyDesc As String Dim MyNum As String Dim MyDwgNum As String Dim FontSize As Textsize oWorkOrder = InputBox("Enter WorkOrderNumber.", "Work Order #!", oWorkOrder) oCustomer = InputBox("Enter Customer.", "Customer", oCustomer) MyDesc = iProperties.Value(modelName, "Summary", "Title") MyNum = iProperties.Value(modelName, "Project", "Part Number") MyDwgRev = iProperties.Value("Project", "Revision Number") ' 'Debug Msg 'MessageBox.Show(oWorkOrder & oCustomer & MyDesc & MyNum & MyDwgRev) With oOMail '.To = "USer@domain.com" .Subject = "<DRAWING APPROVAL NOTIFICATION> <STATUS: HIGH> <W/O# " & oWorkOrder & oCustomer & " / " &MyDesc & "> <DRAWING NUMBER: " & MyNum & "> <REVISION:"& MyDwgRev & " >" .Body.FontSize = 16 .Body = "CRITICAL ACTION: BEN/BONA replace old revisions on the shop floor & at vendor with the new revisions and" .Body = .Body & "destroy the old revisions." .Body = .Body & " " .Body = .Body & "WORK ORDER #: "& oWorkOrder & " / " & oCustomer & " / " & MyDesc .Body = .Body & " " .Body = .Body & "DESCRIPTION OF CHANGES: " .Body = .Body & " " .Body = .Body & "This e-mail is to inform you that the drawing(s) listed below are approved:" .Body = .Body & "Drawing/Part Number Rev Description Status" .Body = .Body & " " .Body = .Body & MyNum & " " & MyDwgRev & " " & MyDesc & " HIGH" .Display '.Send End With
I'm trying to get there by declaring Fontsize, then .Body.Fontsize = 16, but that isn't working. Anyone have a link to a page that would give me the correct format to change font size for this? I'd also like to get the table lines arond the drawing/Part Number, but that isn't critical.
Thanks for looking.
