Format Inventor Property Fields
kevinelliott89
kevinelliott89
Is there a way to format inventor generated property fields, such as the format of units from <MASS> property or the date format of <CREATION DATE>? Example, the default unit for <MASS> for IPS units is "lbmass". Can I set it to just say "lb." or "LB"? It doesn't fit correctly in my titleblock. Same with the date properties.
MechMachineMan
Date format is set by the windows time settings
If nothing else, mass can be set by setting a parameter equal to the weight formatted how you like, then exporting it as an iProperty.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
b_sharanraj
There is nothing to do with Property Field Units in Drawing Title Block.
Because Property Field Units are belongs to Parts & Assemblies.
If you are calling the Units from Parts & Assemblies then we have to go for Custom Property else we have to Edit the Title Block in Drawing.
First Edit the Title Block and check either its a text or Units are called out from Parts & Assemblies.
Regards
B.Sharan Raj
