Form
Form
Form
Hi!
I have a form for adjusting center distances between several posts, up to a total of 20 posts. The number of posts is adjustable depending on how many I need. If there is 10 active posts there will be 10 suppressed post. When there are 10 suppressed post, I don`t need them in the form. Is it possible to hide the center distances I don`t need?
Kind regards.
matt_jlt
Is it iLogic / VBA?
If it's iLogic then I am almost positive the answer is no. I have recently learnt that you can disable the fields not used via the "Enabling Parameter Name" under the "Behavior" Group in the iLogic Form Editor.
If it's VBA then you can simply use:
textfieldname.Visible = False
You could probably do it via an external dll but that is overly complicated for most tasks.
Regards, Matt.
Just what I needed! Thanks! 😄
