for each refdoc
for each refdoc
for each refdoc
hi, hoping for a little help...
how do i get the current file path of each file in an assembly using ilogic?
many thanks for any assistance.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 1789 StartFragment: 314 EndFragment: 1757 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Dim refDocs As DocumentsEnumerator = oInvDoc.AllReferencedDocuments
    Dim refDoc As Document
    For Each refDoc In refDocs
Owner2229
Hi, you can use this below, it'll give you full path and filename of the document (extension included):
refDoc.FullFileName
Then you can work with it to get just the path:
Dim FName As String = refDoc.FullFileName
Dim FNP As Integer = InStrRev(FName, "\", -1)
Dim oPath As String = Left(FName, FNP)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
perfect mike, many thanks!!
