For each Loop & ActiveDocument
joris.engelbertink
Message 1 of 9
joris.engelbertink
Hi All,
So I have this working piece of code that PDF's my active drawing. Now I would like to PDF all open drawings by looping over them, but it's not working. I assume it's because the external rule "PDF Working Folder" is referring to the ActiveDocument. Is there a way of looping over the VisibleDocuments and make them the ActiveDocument?
Any other suggestion is welcome 😉 Thanks in advance!
Grt, Joris
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
If (oDoc.documenttype = kDrawingDocumentObject) Then
iLogicVb.RunExternalRule("PDF Working Folder")
End If
Next oDoc
Replies (8)
Message 2 of 9
FINET_Laurent
You can simply use the Activate command like so :
If oDoc.DocumentType = kPartDocumentObject Then
	oDoc.Activate
End If
Next
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 9
joris.engelbertink
Hi thanks for your reply, that brought me a bit further.
I still have an issue. When printing the ActiveDocument hops to another drawing, but the filename remains the same and only one drawing is printed. Any suggestions on this?
Thanks in advance!
Grt, Joris
Dim FileName As String
		FileName = ThisDoc.PathAndFileName(False) & (".pdf")
		oDrgDoc.PrintManager.PrintToFile(FileName)
Message 4 of 9
FINET_Laurent
Where are those lines situated in the code ? Can you provide the full code ?
My guess is that thoses lines are outside the loop.
Make sure you set the file name to the new active document each time you want to print.
FINET L.
Message 5 of 9
joris.engelbertink
The full code:
Sub Main()
	oDoc.Activate
	End If
Next oDoc
End Sub
Sub Main AutoPDF() AutoPDF To local drawing folder.
    'Print all sheets in drawing document
    'Get the active document and check whether it's drawing document
	On Error GoTo ErrHandler
	If ThisApplication.ActiveDocument.SubType <> "{BBF9FDF1-52DC-11D0-8C04-0800090BE8EC}" Then
	Exit Sub
	End If
	If ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
        Dim oDrgDoc As DrawingDocument
        oDrgDoc = ThisApplication.ActiveDocument
        ' Set reference to drawing print manager
        ' DrawingPrintManager has more options than PrintManager
        ' as it's specific to drawing document
        Dim oDrgPrintMgr As DrawingPrintManager
        oDrgPrintMgr = oDrgDoc.PrintManager
        ' Set the printer name
        ' comment this line to use default printer or assign another one
        oDrgPrintMgr.Printer = "Microsoft Print to PDF" '"Bluebeam PDF"
        'Set the paper size , scale and orientation
        oDrgPrintMgr.ScaleMode = 13826 'kPrintBestFitScale
        oDrgPrintMgr.PaperSize = 14340 'kPaperSizeA3
        oDrgPrintMgr.PrintRange = 14082 'Print all Sheets of the Drawing
		oDrgPrintMgr.ColorMode = 13313	'kPrintColorPalette
		oDrgPrintMgr.Orientation = 13570 'kLandscapeOrientation
        'oDrgPrintMgr.SubmitPrint
        'Set print properties
	Else
	Exit Sub
	End If
	ErrHandler: Exit Sub
End Sub
Message 6 of 9
FINET_Laurent
I don't have much experience with printing using iLogic.
I tried a different approach for setting the file name.. I also removed few things. For instance you are checking if the document is a drawing document, thing you already did in the previous rule.
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim i As Integer = oDoc.DisplayName.Length
Dim oDocName As String = Left(oDoc.DisplayName, (i - 4)) & ".pdf"
	oDrgPrintMgr = oDoc.PrintManager
		Try
			oDrgPrintMgr.PrintToFile(oDocName)
		Catch
			MsgBox("Error")
		End Try
FINET L.
Message 7 of 9
joris.engelbertink
perfect, thanks a lot!
Grt, Joris
Message 8 of 9
dusan.naus.trz
I admit it didn't work for me. I changed the code a bit to make it work. 🙂
'Dim i As Integer = oDoc.DisplayName.Length
'Dim oDocName As String = Left(oDoc.DisplayName, (i - 4)) & ".pdf"
'MessageBox.Show(oDocName, "Title")
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
oDocName = ThisDoc.Path + "\" + modelName + ".pdf"
	oDrgPrintMgr.AllColorsAsBlack = True
		Try
		Catch
			MsgBox("Error")
		End Try
Message 9 of 9
nannerdw
You can add an optional RuleArgument to your rule, so the document doesn't need to be activated.
When it is called as a standalone rule, it will default to ThisApplication.ActiveDocument
If RuleArguments.Exists("oDoc") Then
	oDoc = RuleArguments("oDoc")
Else
	oDoc = ThisApplication.ActiveDocument
End If
In the calling rule:
Sub Main
	If (oDoc.DocumentType = kDrawingDocumentObject) Then
		oDoc.Activate
		Dim map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
		map.Add("oDoc", oDoc)
		iLogicVb.RunExternalRule("PDF Working Folder", map)
	End If
Next oDoc
End Sub
