FlatExtentsLength and FlatExtentsWidth don't match from ipt to iam
Hi Everybody,
I have the following and big problem:
When I place an iPart on the Assembly, copy it and then change the component of the copied iPart in its Table, the FLATEXTENTSLENGTH and FLATEXTENTSWIDTH  of the sheet metal of the iPart simply don't change.
If I measure the iParts they are ok, I mean, they have different dimensions, but their iProperties keep as the same.
¿¿¿Could you help me, please???
Thanks!
Ktomberlin
This really isn't a customization issue and I'm not 100% sure what your looking at, but if you want the iparts to update the Comp and Large iproperties, just add "=<Sheet Metal Length>" and "=<Sheet Metal Width>" of the parent.  This showed the updated sizes.  You might be having an issue with having to update each flat pattern.  Hope this helps.
Thanks a lot, my friend.
After my question I've found the "=<Sheet Metal Length>" and "=<Sheet Metal Width>" too. These ones have different behaviour of the SheetMetal.FlatExtentsLength and the SheetMetal.FlatExtentsWidth. I'd never mind there'd be this difference.
