Flat pattern to dxf with bend line
kresh.bell
kresh.bell
I have ilogic for export flat pattern in dxf which is great for me, could anyone help me and edit it in such a way that it does not generate a tangent line but just a band line (ideally if only the band line were blue in color but that not necessary)
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
	Return
	Else
End If
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
		For Each oRefDoc In oRefDocs
			iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
    		'check that model is saved
			If(System.IO.File.Exists(iptPathName)) Then
                Dim oDrawDoc As PartDocument
                oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
            	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
				Try
                	'Set the DXF target file name
                	oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
					Dim oCompDef As SheetMetalComponentDefinition
					oCompDef = oDrawDoc.ComponentDefinition
					If oCompDef.HasFlatPattern = False Then
						oCompDef.Unfold
					Else
   						oCompDef.FlatPattern.Edit
					End If
					Dim sOut As String
					sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
					oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
					'just for check its works coretcly
					'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
					'MessageBox.Show(i,"title",MessageBoxButtons.OK)
					'If i=2 Then
						'Exit Sub
					'End If
					oCompDef.FlatPattern.ExitEdit
				Catch
				End Try
				oDrawDoc.Close
			Else
			End If
		Next
alewer
Is it OK for you to still have the tangent lines, but have them on an invisible layer? From the API helpfiles, I see no way (using DataIO.WriteDataToFile) to omit tangent lines from the .dxf, but you make the tangent layer (and tangent roll layer) invisible:
ArgumentTypeDefault ValueNote
TangentLayerStringIV_TANGENT
OuterProfileLayerStringIV_OUTER_PROFILE
ArcCentersLayerStringIV_ARC_CENTERS
InteriorProfilesLayerStringIV_INTERIOR_PROFILES
BendLayerStringIV_BENDBendUpLayer + BendDownLayer (legacy support)
BendUpLayerStringIV_BEND
BendDownLayerStringIV_BEND_DOWN
ToolCenterLayerStringIV_TOOL_CENTERToolCenterUpLayer + ToolCenterDownLayer (legacy support)
ToolCenterUpLayerStringIV_TOOL_CENTER
ToolCenterDownLayerStringIV_TOOL_CENTER_DOWN
FeatureProfilesLayerStringIV_FEATURE_PROFILESFeatureProfilesUpLayer + FeatureProfilesDownLayer (legacy support)
FeatureProfilesUpLayerStringIV_FEATURE_PROFILES
FeatureProfilesDownLayerStringIV_FEATURE_PROFILES_DOWN
AltRepFrontLayerStringIV_ALTREP_FRONT
AltRepBackLayerStringIV_ALTREP_BACK
UnconsumedSketchesLayerStringIV_UNCONSUMED_SKETCHES
TangentRollLinesLayerStringIV_ROLL_TANGENT
***ColorString *** indicates name of layer from the argument column. RGB values separated by ;. Example: TangentLayerColor=255;0;0
***LineTypeLong *** indicates name of layer from the argument column. Long value from LineTypeEnum. Example: TangentLayerLineType=37644
***LineWeightDouble *** indicates name of layer from the argument column. Value in centimeters. Example: TangentLayerLineWeight=.1016
CustomizeFilenameString
AcadVersionString 2018, 2013, 2010, 2007, 2004, 2000, or R12 (for DXF only)
SimplifySplinesBooleanTrueEnable spline replacement by linear segments
SplineToleranceDouble0.01Chord tolerance for spline replacement
AdvancedLegacyExportBooleanTrue
MergeProfilesIntoPolylineBooleanFalseBuild a polyline of the exterior profiles
RebaseGeometryBooleanFalseMove geometry to 1st quadrant
InvisibleLayersString List of layer names to make invisible, separated by ;
If moving tangent lines to an invisible layer is acceptable, replace this existing line of code:
With this:
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE&InvisibleLayers=IV_TANGENT;IV_ROLL_TANGENT"
If an invisible layer is not an acceptable solution, I recommend that you look into exporting flat pattern geometry to .dxf using the dxf TranslatorAddin. This allows you to control layers by .ini files, much like a "manual" (GUI) export to .dxf.
