flat pattern generation from assembly
I have some problem with ILogic. I'm trying to do some rule to generate .dxf files of flat pattern form each sheet metal parts.  I have rule that works in single part document but i cant create it for assembly.
I would like to run this rule manually when i finish each project. And i want to all those .dxf be in one folder called "DXF" just like my rule.
Here goes my code for single .ipt
i = MessageBox.Show("Czy chcesz zapisać rozwinięcie blachy?", "Zapis .dxf", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
	If (i=6)
Dim oDoc As PartDocument
oDoc = ThisApplication.ActiveDocument
''ThisDoc.Launch(ThisDoc.PathAndFileName(True))
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
    oCompDef.Unfold
Else
   oCompDef.FlatPattern.Edit
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
Dim sFname As String
sFname = ThisDoc.FileName(False)
'sFname = Left$(sFname, Len(sFname)-4) & ".dxf"
oPath = ThisDoc.Path
oFolder = oPath & "\" & "DXF"
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
sciezka = oFolder & "\" & sFname & ".dxf"
oCompDef.DataIO.WriteDataToFile( sOut, sciezka)
oCompDef.FlatPattern.ExitEdit
''ThisDoc.Document.Close
It works great for me.
Can someone can help me with this?
Well, its looks like ive done it by myself with connecting a few codes and changing them a little bit.
It works. Rule for each sheet metal save .DXF unfolded copy on special folder where assembly is.
perhaps this code is too complicated but it works for now , later I will improve it
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
	Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
	Return
	Else
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
'- - - - - - - - - - - - -Component  - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
		For Each oRefDoc In oRefDocs
			iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
    		'check that model is saved
			If(System.IO.File.Exists(iptPathName)) Then
                Dim oDrawDoc As PartDocument
                oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
            	oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
				Try
                	'Set the DXF target file name
                	oDataMedium.FileName = oFolder & "\" & oFileName & ".dxf"
					oCompDef = oDrawDoc.ComponentDefinition
						oCompDef.Unfold
					Else
					Dim sOut As String
					oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
					'just for check its works coretcly
					'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
					'MessageBox.Show(i,"title",MessageBoxButtons.OK)
					'If i=2 Then
						'Exit Sub
					'End If
				Catch
				End Try
				oDrawDoc.Close
			Else
		Next
I know this post is old but if you see this do you know if there is a way to change the export settings in the rule?  I want it to put the all the profiles on one layer all the bend on one layer and omit the tangent lines and arc centers.  any help would be greatly appreciated.
