Flat pattern export with bend lines properties
valdas_kulikajevasYW7SV
I have an export of sheet metal flat patterns, and would like to make "Bend Lines" as "dashed dot" and yellow layer when exported to dxf.
Is there a way to simply update the code to have this change?
                Dim sOut As String
                'sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER_DOWN;IV_BEND;IV_BEND_DOWN"
 				sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&InvisibleLayers=IV_ARC_CENTERS;IV_TANGENT;IV_ROLL;IV_ROLL_TANGENT;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_FEATURE_PROFILES_DOWN;IV_FEATURE_PROFILES;IV_TOOL_CENTER_DOWN;" _
				+ "IV_BEND=1;IV_BEND_DOWN=1"
				oCompDef.DataIO.WriteDataToFile(sOut, newFileName)
                'oCompDef.DataIO.WriteDataToFile(sOut, oDataMedium.FileName)
                oCompDef.FlatPattern.ExitEdit()
johnsonshiue
Hi! This does not require change in the code. You need to change the Configuration .ini file. Try the workflow manually. In the DXF Export wizard dialog, select Layer tab and make the change -> save the settings as a configuration ini file. Next time when exporting the flat pattern to DXF, make sure the .ini file is chosen.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Thank you, @johnsonshiue , for your reply. How exactly can this be setup? and does it work with ilogic code, that I have provided in the question?
'check that the active document is an assembly file
        '--> first check if the is an assembly before you declare it to an AssemblyDocument
        If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
            MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
            Exit Sub
        End If
        'define the active document as an assembly file
        Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
        '--> oAsmDoc.DisplayName can show the extension depending on windows settings.
        '--> i guess that you try to remove the extensin here.
        '--> if you do it in this way your colega, with different windows settings, will have an unexpexted resilt.
        'Dim oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) - 4)
        Dim oAsmName = oAsmDoc.DisplayName.Replace(".iam", "")
        'get user input
        Dim RUsure = MessageBox.Show(
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo)
        If RUsure = vbNo Then
            Return
            ' Else <-- this is not needed.
        End If
        Dim oPath = ThisDoc.Path
        '--> it seems that you use oDataMedium only for the file path.
        '--> you might want to have a look at the k.i.s.s. design principl
        '--> https://en.wikipedia.org/wiki/KISS_principle
        '--> i think you wont need it.
        'Dim oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
        '--> oContext is declared her but is never used...
        'Dim oContext = ThisApplication.TransientObjects.CreateTranslationContext
        'oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        '--> oOptions is declared her but is never used...
        'Dim oOptions = ThisApplication.TransientObjects.CreateNameValueMap
        'get DXF target folder path
        Dim oFolder = oPath & "\" & oAsmName & " DXF Files"
        'Check for the DXF folder and create it if it does not exist
        If Not System.IO.Directory.Exists(oFolder) Then
            System.IO.Directory.CreateDirectory(oFolder)
        End If
        '- - - - - - - - - - - - -'- - - - - - - - - - - - -Component - - - - - - - - - - - -
        'look at the files referenced by the assembly
        Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
        'work the the drawing files for the referenced models'this expects that the model has been saved
        For Each oRefDoc As Document In oRefDocs
            '--> this seem to replase the extension of the filename. Then you try to check with this
            '--> if it is saved (and probaly if its an part and not an assembly)
            '--> you can better use the Document.Dirty property. this will be false if the file is not saved.
            '--> also if the file exists but was not saved.
            '--> for checking if its a part we can use the Document.DocumentType.
            '--> last i did not see if you checked if it is realy a sheet metal part.
            '--> we can do that with the Document.SubType
            'Dim iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
            'check that model is saved
            'If (System.IO.File.Exists(iptPathName)) Then
            '--> check if its a part:
            If (oRefDoc.DocumentType <> DocumentTypeEnum.kPartDocumentObject) Then
                Continue For '--> this will make the program go to the next oRefDoc
            End If
            '--> check if its a Sheetmetal part:
            If (oRefDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then
            End If
            '--> check if its saved:
            If (oRefDoc.Dirty = True) Then
                '--> TODO ask the user if he/she wants to save?
                '--> oRefDoc.Save()
            End If
            Dim oDrawDoc As PartDocument = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
            Dim oFileName = oRefDoc.DisplayName.Replace(".ipt", "")
            Dim oCompDef As SheetMetalComponentDefinition = oDrawDoc.ComponentDefinition
            Try
                'Set the DXF target file name
                '--> you need to declare the CustomName before the try/cath or you will only be able to use its value in try/cath statement
                '--> i also declared the other values that you asked for. (with there default values so i dont have to do it in the cath block)
                Dim customPropertiesSet = oRefDoc.PropertySets.Item("Inventor User Defined Properties")
                Dim customName As String = "XXX"
                Try
                    customName = customPropertiesSet.Item("PF_PRT_ZNR").Value
                Catch
                    '--> TODO create a msgbox to want the user that the name can be starnge
                    'customName = "XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
                End Try
                Dim designTrackingPropertiesSet = oRefDoc.PropertySets.Item("Design Tracking Properties")
                Dim description As String = designTrackingPropertiesSet.Item("Description").Value
				Dim partnumber As String = designTrackingPropertiesSet.Item("Part Number").Value
                Dim StockNumber As String = designTrackingPropertiesSet.Item("Stock Number").Value
				Dim iQTY As String = customPropertiesSet.Item("iQTY").Value
               ' Dim Material As String = oCompDef.ActiveSheetMetalStyle.Material.Name
				Dim Mat2 As String = designTrackingPropertiesSet.Item("Material").Value
                'oDataMedium.FileName = oFolder & "\" & CustomName & " " & oFileName & ".dxf"
                Dim newFileName As String =
                    oFolder & "\" & partnumber & " " & Mat2 & " " & StockNumber & " " & iQTY & "vnt.dxf"
                If oCompDef.HasFlatPattern = False Then
                    oCompDef.Unfold()
                Else
                    oCompDef.FlatPattern.Edit()
                End If
                Dim sOut As String
				+ "IV_BEND;IV_BEND_DOWN"
				'+ "IV_BEND=1;IV_BEND_DOWN=1"
            Catch
            End Try
            oDrawDoc.Close()
            'Else
            'End If
        Next
Full code bellow
