Find Node from occurrence
dialunau
dialunau
Hello everyone, I'm trying to get the node where a certain occurrence is located in the browser so I can expand that node and see the items related to this component, but whenever I try to get the node from the occurrence I'm getting an "unspecified error" message.
Do you have any ideas for what is causing this error?
This is my code so far:
Sub Main
	Dim oDrawDoc As DrawingDocument = ThisDoc.Document
	Dim oSheet As Sheet = oDrawDoc.ActiveSheet
	Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
	Dim oAssyDoc As AssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
	Dim oOcc As ComponentOccurrence = oAssyDoc.ComponentDefinition.Occurrences.Item(2)
	MsgBox(oOcc.Name)
	Dim oBP As BrowserPane = ThisDoc.Document.BrowserPanes.Item("Model")
	Dim oNode As BrowserNode = oBP.GetBrowserNodeFromObject(oOcc)
End Sub
WCrihfield
Is there more than one view of the assembly within the whole drawing document?  If so, there might be multiple instances of that component found within the entire model browser tree of the drawing.  Just one thought.  You may have to get the node for the view first, then iterate down through the BrowserNodes below that point, perhaps using a recursive routine, to identify the one for that specific component.
Wesley Crihfield
(Not an Autodesk Employee)
dialunau
I just deleted the rest of them so I can only have view 1 and unfortunately I still have the same result.
A.Acheson
This example post talks about the same error. It looks like you get the drawing view node then iterate through the nodes to get to the node you need. If you look at the nativeobject you can match the occurrence. Here is a sample I kindly had some help with that showed the methods to use.
Regards
Alan
dialunau
I tested the code and it works fine. The problem is that it expands all the instances of that occurrence in the browser. I somehow managed to expand only one instance of a specific view. However, this will only work in the specific case that the view I'm looking for is the second iteration of the occurrence instance.
I've been trying to get the exact node of the specific occurrence regardless of the order or the type of the views (namely a section, detail or isometric view) but haven't had luck yet.
Any suggestions?
The code looks like this:
Sub Main()
		'//// GET THE OCCURRENCE NAME TO FIND THE NODE ////
		Dim oOccName = "Insulation1:1"
oDrawDoc = ThisApplication.ActiveDocument Dim oBP As BrowserPane = oDrawDoc.BrowserPanes.Item("Model") oBP.Activate Dim oTNode As BrowserNode = oBP.TopNode Dim objColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection Dim oSheet As Sheet = ThisApplication.ActiveDocument.ActiveSheet Dim oView As DrawingView = oSheet.DrawingViews.Item(2) Dim oCount As Integer = 0 Call Get_SelectedNodes(oTNode, objColl, oOccName, oView) '//// EXPAND THE SECOND VIEW //// Dim oNode As BrowserNode For Each oNode In objColl oCount = oCount + 1 If oSheet.DrawingViews.Item(oCount) Is oView Then oNode.Expanded = True oNode.DoPreSelect() oNode.DoSelect() Exit For End If Next oNode End Sub Public Sub Get_SelectedNodes(oTNode As BrowserNode, ByRef objColl As ObjectCollection, oOccName As String, oView As DrawingView) Dim oNode As BrowserNode For Each oNode In oTNode.BrowserNodes If oNode.BrowserNodeDefinition.Label = oOccName Then Call objColl.Add(oNode) ElseIf oNode.BrowserNodes.Count > 0 Then Call Get_SelectedNodes(oNode, objColl, oOccName, oView) ElseIf oNode.BrowserNodes.Count < 0 Then End If Next End Sub
A.Acheson
It looks like you made good progress. Here is a version that will look for the occurrence in each view of the sheet and expand if found, I added an error catch as there is some exceptions found.
Sub Main()
		Dim oOccName As String = "1237-M-001:1"
		Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
		oBP.Activate
		On Error Resume Next
		For Each oView As DrawingView In oSheet.DrawingViews
			'Get the browser node definition of the drawing view
			Dim oNativeBrowserNodeDef As NativeBrowserNodeDefinition
			Dim oViewNode As BrowserNode
			'Use the try statement or On Error as a child view will not be a Native Browser Definition,
			'it will be picked up By the recursion Loop later
			oNativeBrowserNodeDef = oDrawDoc.BrowserPanes.GetNativeBrowserNodeDefinition(oView)
			'Get the browser node Of the View Using the browser node definition
			oViewNode = oTNode.AllReferencedNodes(oNativeBrowserNodeDef).Item(1)
			oViewNode.DoPreSelect()
			oViewNode.DoSelect()
			'MessageBox.Show(oViewNode.BrowserNodeDefinition.Label, "Drawing View Title")
			oCount = oCount + 1
		    Call Get_SelectedNodes(oViewNode , objColl, oOccName, oView)
			'//// EXPAND THE SPECIFIC Object ////
					Logger.Info(oNode.FullPath)
						oNode.DoPreSelect()
						oNode.DoSelect()
			    Next oNode
			Next
	End Sub
	Public Sub Get_SelectedNodes(oViewNode As BrowserNode, ByRef objColl As ObjectCollection, oOccName As String, oView As DrawingView)
	    For Each oNode In oViewNode.BrowserNodes
		        End If
		Next
	End Sub
Regards
Alan
