find dervied base model in asembly
NachoShaw
Advisor Advisor
NachoShaw
Hi
Please see image. How can i find these derived base model parts to suppress them by using code only?
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
dano0310
Hi Nacho
See if this is what you are chasing
Sub Derived_Part_Hider()
    'Turns off all parts which have a derived feature as the first feature
    '4/02/2016
    Dim oAssyDoc As Document
    Set oAssyDoc = ThisApplication.ActiveDocument
    If oAssyDoc.DocumentType = kAssemblyDocumentObject Then
        Dim oOccs As ComponentOccurrences
        Set oOccs = oAssyDoc.ComponentDefinition.Occurrences
        Dim oOcc As ComponentOccurrence
        For Each oOcc In oOccs
            If oOcc.DefinitionDocumentType = kPartDocumentObject Then
                If oOcc.Definition.Features(1).Type = kReferenceFeatureObject Then oOcc.Visible = False
            End If
        Next
    Else
        Exit Sub
    End If
End Sub
Regards
Dan
