Find broken constraints
ndillner343SKL
ndillner343SKL
Hello, is it possible to find and identify which constraints are broken within an assembly?
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	Dim oConstraint As AssemblyConstraint = oAsm.ComponentDefinition.Constraints.Item("Flush:5") 'Name of constraint
	Dim oOcc2 As ComponentOccurrence = oConstraint.AffectedOccurrenceTwo
	Dim oOccDoc As Document = oOcc2.Definition.Document
	iLogicVb.Automation.GetNamedEntities(oOccDoc).GetName(oConstraint.EntityTwo.NativeObject)
	Dim Msg As String = "Entity 2 Name: " & iLogicVb.Automation.GetNamedEntities(oOccDoc).GetName(oConstraint.EntityTwo.NativeObject) & "Offset parameter: " & oConstraint.Offset.Name
	MsgBox(Msg)
Michael.Navara
At the beginning you can try this code snippet.
It prints all constraint with HealthStatus different from kUpToDateHealth
Dim asm As AssemblyDocument = ThisDoc.Document
For Each c As AssemblyConstraint In asm.ComponentDefinition.Constraints
	If c.HealthStatus <> HealthStatusEnum.kUpToDateHealth Then
		Logger.Warn("Invalid contraint: {1}{0}Occurrences:{0}{2}{0}{3}", vbCrLf, c.Name, c.OccurrenceOne.Name, c.OccurrenceTwo.Name)
Next
ndillner343SKL
Thank you @Michael.Navara! This will really help me get started. Where can I find a list of variables for assemblies? "HealthStatus" for example. I had no Idea this variable existed.
WCrihfield
HealthStatusEnum (Link1, Link2)
...to find this, and more, go to your online help web page:
https://help.autodesk.com/view/INVNTOR/2022/ENU
Then follow below visual categories
Wesley Crihfield
(Not an Autodesk Employee)
Michael.Navara
Usually I use my tool: VBA Object Browser for Inventor
And also API Help for Inventor as @WCrihfield mentions above is very usefull
