- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, is it possible to find and identify which constraints are broken within an assembly?
Dim oAsm As AssemblyDocument = ThisDoc.Document Dim oConstraint As AssemblyConstraint = oAsm.ComponentDefinition.Constraints.Item("Flush:5") 'Name of constraint Dim oOcc2 As ComponentOccurrence = oConstraint.AffectedOccurrenceTwo Dim oOccDoc As Document = oOcc2.Definition.Document iLogicVb.Automation.GetNamedEntities(oOccDoc).GetName(oConstraint.EntityTwo.NativeObject) Dim Msg As String = "Entity 2 Name: " & iLogicVb.Automation.GetNamedEntities(oOccDoc).GetName(oConstraint.EntityTwo.NativeObject) & "Offset parameter: " & oConstraint.Offset.Name MsgBox(Msg)
