hi,
if it could help someone one day
The code updated to search the text on all the sheets
An additional window will tell you the number of occurrences founded on each sheet and you will have to choose if you apply or not to all sheets
Thanks all
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Return
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Inventor.Sheet = oDDoc.ActiveSheet
'<<< set initial values to 'shared' variables >>>
oDNotes = oSheet.DrawingNotes
oTO = ThisApplication.TransientObjects
oHLS = oDDoc.CreateHighlightSet
oHLS.Color = oTO.CreateColor(255, 0, 0, 1) 'Red - Opaque
oFoundDNotesColl = oTO.CreateObjectCollection
sFind = ""
sNew = ""
'<<< done setting initial values >>>
'<<< following is a designated marker for a place to jump to later (using GoTo) >>>
StartOfRepeat:
'<<< all following code may repeat, so clear the 3 collections >>>
oHLS.Clear
oFoundDNotesColl.Clear
'<<< get required inputs from user - exit if nothing entered >>>
sFind = InputBox("Entrer le texte a remplacer", "Search...", "")
If sFind = "" Then Return
sNew = InputBox("Entrer le texte de remplacement", "...and replace", "")
If sNew = "" Then Return
'<<< conduct searches >>>
FindReplace(False) 'False means SearchOnly, no Replace
'<<< inspect findings, react appropriately >>>
If oHLS.Count > 0 Then
' Count the occurrences found
Dim occurrencesCount As Integer = oHLS.Count
Dim oAns As DialogResult = MessageBox.Show("Il y a " & occurrencesCount & " occurrence(s) trouvée(s)." & vbCrLf & _
"Les textes surlignés seront remplacés." & vbCrLf & _
"Procéder aux remplacements ? [Oui]" & vbCrLf & _
"Enlever certains textes du remplacement ? [Non]" & vbCrLf & _
"Annuler la fonction ? [Annuler]", "Textes trouvés", _
MessageBoxButtons.YesNoCancel, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
If oAns = DialogResult.Cancel Then
GoTo MaybeFinished
ElseIf oAns = DialogResult.Yes Then
FindReplace(True) 'True means do Replace process
ElseIf oAns = DialogResult.No Then
RemoveSelectedFromEditGroup
End If
End If
'<<< Demander si appliquer à toutes les feuilles >>>
' Calculez les occurrences par feuille
Dim occurrencesPerSheet As String = CountOccurrencesPerSheet()
' Affichez le nombre d'occurrences par feuille dans la boîte de dialogue
Dim oApplyAll As DialogResult = MessageBox.Show("Occurrence(s) à remplacer par feuille:" & vbCrLf & occurrencesPerSheet & _
vbCrLf & "Appliquer les remplacements à toutes les feuilles ?", _
"Partout ?", MessageBoxButtons.YesNo, _
MaybeFinished:
If oApplyAll = DialogResult.Yes Then
ApplyToAllSheets
End If
' Relancer la fonction ? (Placé tout à la fin)
Dim oAgain As DialogResult = MessageBox.Show("Relancer la fonction? [Oui]" & vbCrLf & "Ou sortir de la fonction? [Non]", "Encore ?", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button2)
If oAgain = DialogResult.Yes Then GoTo StartOfRepeat
End Sub
'declare variables here that all routines will need access to
Dim oDNotes As Inventor.DrawingNotes
Dim oTO As TransientObjects
Dim oHLS As Inventor.HighlightSet
Dim oFoundDNotesColl As ObjectCollection
Dim sFind As String
Dim sNew As String
Sub FindReplace(ByVal bReplace As Boolean)
If bReplace = False Then
If oDNotes.Count > 0 Then
For Each oDNote As Inventor.DrawingNote In oDNotes
If oDNote.FormattedText.Contains(sFind) Then
oFoundDNotesColl.Add(oDNote)
End If
Next
oHLS.Clear
Try : oHLS.AddMultipleItems(oFoundDNotesColl) : Catch : End Try
End If
Else
If oFoundDNotesColl.Count > 0 Then
For Each oDNote As Inventor.DrawingNote In oFoundDNotesColl
Try : oDNote.FormattedText = oDNote.FormattedText.Replace(sFind, sNew) : Catch : End Try
Try : oFoundDNotesColl.RemoveByObject(oDNote) : Catch : End Try
Try : oHLS.Remove(oDNote) : Catch : End Try
Next
End If
End If
End Sub
Sub RemoveSelectedFromEditGroup()
Dim oSelDNote As DrawingNote = Nothing
Dim oFilter As SelectionFilterEnum = SelectionFilterEnum.kDrawingNoteFilter
Dim sPrompt As String = "Selectionner le texte à enlever de l'édition" & vbCrLf & "Pour sortir de la sélection, appuyer sur échap"
Do
oSelDNote = Nothing
oSelDNote = ThisApplication.CommandManager.Pick(oFilter, sPrompt)
If oSelDNote Is Nothing Then Exit Do
For Each oDNote As DrawingNote In oFoundDNotesColl
If oDNote Is oSelDNote Then oFoundDNotesColl.RemoveByObject(oDNote)
Next
Try : oHLS.Clear : oHLS.AddMultipleItems(oFoundDNotesColl) : Catch : End Try
End If
Loop Until oSelDNote Is Nothing
End Sub
Function CountOccurrencesPerSheet() As String
Dim occurrencesPerSheet As String = ""
Dim totalOccurrences As Integer = 0
' Parcourir chaque feuille et compter les occurrences
For Each oSheet As Sheet In oDDoc.Sheets
Dim sheetOccurrences As Integer = 0
If oSheet IsNot oDDoc.ActiveSheet Then ' Éviter de refaire sur la feuille actuelle
Dim oDNotes As DrawingNotes = oSheet.DrawingNotes
For Each oDNote As DrawingNote In oDNotes
sheetOccurrences += 1
End If
Next
End If
' Ajoutez le nombre d'occurrences pour cette feuille
occurrencesPerSheet &= oSheet.Name & ": " & sheetOccurrences & " occurrences" & vbCrLf
totalOccurrences += sheetOccurrences
Next
' Ajoutez le total global
occurrencesPerSheet &= vbCrLf & "Total : " & totalOccurrences & " occurrences"
Return occurrencesPerSheet
End Function
Sub ApplyToAllSheets()
' Parcourir chaque feuille et effectuer le remplacement
totalOccurrences += 1
Try
Catch
End Try
End If
Next
End If
Next
MessageBox.Show("Remplacement effectué sur toutes les feuilles. Total d'occurrences remplacées: " & totalOccurrences, "Terminé", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
