Find and Open Excel File in Folder
eric.frissell26WKQ
Message 1 of 12
eric.frissell26WKQ
I'm curious if anyone knows a method to open an excel document from a partial string in a given directory?
Example say you have all of your project folders on a drive, inside your project folders you have project documents, and you're specifically looking for Project File - (JobNumber) where JobNumber is simply the job number (except it varies from job to job, of course).  If you didn't know the job number but knew the "Project File" keyword do not change, any idea how you would open it?
Replies (11)
Message 2 of 12
A.Acheson
Do you have a sample file path string that shows the project file and job number?  Also indicate if the location will always be different. If the excel document is relative to an assembly/part file then that can be used as a location marker.
Regards
Alan
Message 3 of 12
Curtis_Waguespack
Hi @eric.frissell26WKQ
Here is an example that might work for you.
I hope this helps.
Curtis
Sub Main
	Dim oWord As String = "123"
	SearchThroughFolders("C:\Temp\", oWord)
End Sub
Sub SearchThroughFolders( oFolder As String, oSearchWord As String)
	Dim oSubDirectories As String() = System.IO.Directory.GetDirectories(oFolder)
	Dim oFiles As String() = System.IO.Directory.GetFiles(oFolder,"*.xls")
	For i = 0 To oSubDirectories.Length - 1
		SearchThroughFolders(oSubDirectories(i), oSearchWord)
	Next
	For i = 0 To oFiles.Length - 1
		If oFiles(i).ToUpper().Contains(oSearchWord.ToUpper()) Then
			ThisDoc.Launch(oFiles(i))
		End If
	Next
End Sub
Message 4 of 12
Michael.Navara
This is a shorter version mentioned by @Curtis_Waguespack
Dim topDirectory = "C:\Temp"
Dim searchPattern = "Project File - (*).*"
Dim files = System.IO.Directory.EnumerateFiles(topDirectory, searchPattern, System.IO.SearchOption.AllDirectories)
For Each file In files
	Logger.Debug(File)
Next
Message 5 of 12
eric.frissell26WKQ
Thanks guys!  Really appreciating the help!  Granted I was hoping I wouldn't have to do this but... tried both methods and struggling to get either to work.  Perhaps you guys might be able to see if I made an error in implementing your methods so here's the code in it's entirety so far.
Currently intent is to;
set a path to the project folder (DocPath) as a parameter so that it can be called at a later date, and do the same to the engineering path which is what holds the engineering documents.
Have this iLogic rule find the document containing the word Sizing, open it (silent, not silent - both are okay), and adjust some values based on what's contained in the file.
Currently the parameters are being set however using either of the two methods are not returning anything - the SearchThroughFolders isn't opening the file and using the directory nothing is printing to the logger
Were these set up right?  Been going through and trying a few different ways of getting them to work but haven't been able to return anything
Sub Main()
Dim DocPath As String
On Error Resume Next
DocPath = Parameter("ProjectFolder")
If DocPath = "" Then Search(DocPath)
	'DocParam = InputBox("Set Project Folder Directory.  If there are sub-directories prior to project information then use sub directory")
	'AddPathParam = ParamSet.AddByValue("ProjectFolder", DocParam, UnitsTypeEnum.kTextUnits)
EngineeringPath = Parameter(EngineeringPath)
Dim topDirectory = DocPath
Dim searchPattern = "*Sizing*"
	Logger.Debug(File)
Next
End Sub
' Set document paths and create parameters
Sub Search(DocPath As String)
	' Create param
	ParamSet = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
	DocParam = InputBox("Set Project Folder Directory")
	' Set Path
	If Right(DocPath, 0) <> "\" Then
		DocPath = DocPath & "\"
	End If
	' Create engineering path
	EngineeringPath = DocPath & "Engineering\"
		'MsgBox(EngineeringPath)
	AddPathParam = ParamSet.AddByValue("EngineeringPath", EngineeringPath, UnitsTypeEnum.kTextUnits)
	Dim oWord As String = "Sizing"
	'Search2(EngineeringPath, oWord)
	'SearchThroughFolders(EngineeringPath, oWord)
End Sub
' Find the files
Sub SearchThroughFolders( DocPath As String, oWord As String)
	Dim oSubDirectories As String() = System.IO.Directory.GetDirectories(EngineeringPath)
	Dim oFiles As String() = System.IO.Directory.GetFiles(DocPath, "*.xlsx")
		SearchThroughFolders(oSubDirectories(i), oWord)
	Next
		If oFiles(i).ToUpper().Contains(oWord.ToUpper()) Then
		End If
	Next
End Sub
Sub Search2(EngineeringPath As String, oWord As String)
	Dim topDirectory = EngineeringPath
Dim searchPattern = "*" & oWord & "*.*"
	Logger.Debug(File)
Next
End Sub
Message 6 of 12
Michael.Navara
I look at your code later, but first thing.
NEVER use On Error Resume Next in iLogic rules. This is an obsolete method for error handling. Use Try-Catch blocks instead.
Message 7 of 12
eric.frissell26WKQ
Just circling back to this in case anyone can see the error in the code above
Try -catch block seems like a difficult way of implementing the on error resume next.  Mind if I ask why try-catch is better?  Was using On Error to get through the initial object variable not being set and tried to switch it to try-catch but it kept failing, though I'll admit that may be the first try-catch I tried to implement.
Would it be appropriate to do something like
If Err then GoTo ...
Message 8 of 12
Michael.Navara
Unstructured error handling is not recommended by Microsoft.
How to implement Try-Catch-Finally block is described here.
Usually you don't want to continue, when some unexpected exception occurs. You need to fix them first and then you can continue. Otherwise you can get unexpected behavior of your code.
Message 9 of 12
Curtis_Waguespack
Hi @eric.frissell26WKQ,
As currently written you only enter the sub called "Search" if DocPath is nothing. So if DocPath is not nothing, it never steps into that sub, and therefore never searches for the file or opens it is found.
That might be the intent, but I wanted to point that out in case it was not.
In any case, here is an example that should be closer to what you are wanting.
I hope this helps.
Curtis
Sub Main
	' get or create param
	oParamName = "ProjectFolder"
	Call CheckOrCreateParam(oParamName)
	'get user input
	DocPath = InputBox("Set Project Folder Directory", "iLogic", Parameter(oParamName))
	If DocPath = "" Then Return
	'set param value
	Parameter(oParamName) = DocPath
	End If
	oParamName = "EngineeringPath"
	'set param value
	Parameter(oParamName) = DocPath & "Engineering\"
	oFile = SearchThroughFolders(Parameter(oParamName), "Sizing")
	If oFile = "" Then : MsgBox("No file found.", , "iLogic") : Exit Sub : End If
	Try : GoExcel.Open(oFile, "Sheet1") : _
	Catch : MsgBox("could not open Excel file.", , "iLogic") : Exit Sub : End Try
	oCellValue = GoExcel.CellValue("A1")
	MsgBox("Cell value is: " & oCellValue,, oFile)
End Sub
Function CheckOrCreateParam(oName)
	Try
		'get param value
		oTest = Parameter(oName)
	Catch
		'create if not found
		ParamSet.AddByValue(oName, "", UnitsTypeEnum.kTextUnits)
	End Try
	InventorVb.DocumentUpdate()
End Function
' Find the files
Function SearchThroughFolders(oFolder As String, oWord As String)
	Dim oFiles As String() = System.IO.Directory.GetFiles(oFolder, "*.xlsx")
			Return oFiles(i)
		End If
	Next
End Function
Message 10 of 12
eric.frissell26WKQ
Thanks Curtis!  You're right about the file search function - I would like to run the file location function once and have it store the values, then be able to run the entire sub again and and have it update so it wouldn't have done that the way it was written.
I'll be trying this soon and thanks a ton for writing this out, gonna have a lot to learn from it.
Message 11 of 12
eric.frissell26WKQ
While I've got you here, hopefully you wouldn't mind a quick question?  I'm not very familiar with try catch methods and I'm trying to understand some behavior...  Your code worked however the I made a few edits in the first few lines and was trying to get the code to skip the inputbox if it found the parameter.  The On Error Resume Next I thought was a really simple way to get through this however I understand that it's not the greatest way to handle errors.  If that was converted to a try catch method I'd think it'd look somewhat similar to the code below, except it's not running that way
Is the right way to think about a try-catch method like;
Do X  <- the try
If you can do X go on
If you can't do X then do Y <- the catch
Sub Main()
	' Check for parameter
	Try : DocPath = Parameter(ProjectFolder)
		If DocPath <> ""
			MsgBox(DocPath)
		End If
	Catch : ' didn't find parameter - go to create parameter
		Call CheckOrCreateParam(oParamName) : End Try
	' Get user input for parameter
	DocPath = InputBox("Set Project Folder Directory.  Leave blank to exit", "iLogic", Parameter(oParamName))
	If DocPath = "" Then Exit Sub
	' Set param value
	End If
Message 12 of 12
Curtis_Waguespack
The problem with using On Error Resume Next (OERN) on it's own, is that is can hide errors and make debugging a terror when the code just doesn't work, but it doesn't tell us it didn't work because the OERN is silencing the errors.
I still do it from time to time, but it's generally considered poor practice.
If you are going to use it, it should be used with a proper error catch. You can Google "VBA error handlers" and find a bunch of info on that.
The other thing to know is that you can not use OERN in the same code as Try/Catch statements. And Try/Catch statements are really useful.
With all of that said. I did mix a lot of syntactical try/catch stuff in my previous reply, so let me see if I can clear things up.
These 4 do the same thing:
1) This one catches and handles the error separately from the remedy action, which is in the Finally.
Try 'try to get the value
	otest = Parameter(oParamName)
Catch 'catch the error when the param isn't found
	MsgBox("Param not found")
Finally
End Try
2) This one catches and handles the error in step with the remedy action.
End Try
3) This one catches and handles the error in step with the remedy action, but all in one line.
Try: otest = Parameter(oParamName): Catch: MsgBox("Param not found"): Call CheckOrCreateParam(oParamName): End Try
4) this one is doing the same thing, but is just using the colons to combine the Catch and End Try lines
Catch: 	MsgBox("Param not found"): Call CheckOrCreateParam(oParamName):End Try
Or if no message box is needed, we could do this:
End Try
or this one liner does the same as the last one:
Try: otest = Parameter(oParamName): Catch: Call CheckOrCreateParam(oParamName): End Try
Typically though you'll see this:
Try
	' do something here
Catch
	'catch the error when the something didn't work
End Try
Note too that you can catch the error message and hand that back to the user like this:
Try
	' do something here
Catch ex As Exception
	Messagebox(ex.Message)
Finally
	'do the remedy for the something that didn't work
End Try
I hope this helps.
Curtis
