Find all holes in idw and set their layer through VBA
insomnix
insomnix
Just as the title states. I want to change the layer of every hole in an idw to the holes layer. This idw will iterate through a factory and export to individual files that will then be imported into another program for the machines to make the parts. My code is long, so I will place the portion that I am working on:
        If createProgram = "Y" Then
            oMemberProgramTemplate = oRow.Item(iProgramTemplateColumnIndex).Value
            If Len(Dir(templatesfileLocation & oMemberProgramTemplate & ".idw")) > 0 Then
                'get the drawing template
                Set oDrawingDoc = ThisApplication.Documents.Open(templatesfileLocation & oMemberProgramTemplate & ".idw")
                Set oSheet = oDrawingDoc.ActiveSheet
                Dim oHoleLayer As Layer
                oHoleLayer = oDrawingDoc.StylesManager.Layers.Item("holes")
                'get the drawing view
                Dim oViewDin As DrawingView
                For Each oViewDin In oSheet.DrawingViews
                    Select Case oViewDin.Name
                        Case "ALPHA"
                            Call oViewDin.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(ipartsfileLocation & oMemberFile)
                            'Dim oHoles As HoleFeatures
                            oViewDin.IsRasterView = False
                        Case Else
                    End Select
                Next
                'save copy as one new idw using the member name in the prints folder
                Call oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".dwg", True)
                Call oDrawingDoc.Close
            End If
        End If
 As you can probably see I am changing the view in the select statement, and it is here I believe the holes should be found and the layer set. I have already created a variable, oHoleLayer, that I need to apply to the holes. Size of the holes do not matter, the importing program will detect the size, I just need to tell the program to drill those holes by setting them to that layer.
insomnix
I've made some progress, but now I'm running into another problem. "Case 5124" does return all the circles, but it is also grabbing a few lines. There does not appear to be any reason why these lines are changing layer's but I would apprecieate any insite. I have attached a snapshot of what the exported dwg looks like.
                Set oHoleLayer = oDrawingDoc.StylesManager.Layers.Item("holes")
                        Case "ALPHA"
                            Set oDrawViewCurves = oViewDin.DrawingCurves()
                            For Count = 1 To oDrawViewCurves.Count
                                Set oCircularCurve = oDrawViewCurves.Item(Count)
                                Select Case oCircularCurve.CurveType
                                    Case 5121:
                                        'Debug.Print "Unknown curve type."
                                    Case 5122:
                                        'Debug.Print "Line curve."
                                    Case 5123:
                                        'Debug.Print "Line segment curve."
                                    Case 5124:
                                        'Debug.Print "Circular curve."
                                        For Each oSEG In oCircularCurve.Segments
                                            oSEG.Layer = oHoleLayer
                                        Next oSEG
                                    Case 5125:
                                        'Debug.Print "Circular arc curve."
                                    Case 5126:
                                        'Debug.Print "Ellipse full curve."
                                    Case 5127:
                                        'Debug.Print "Elliptical arc curve."
                                    Case 5128:
                                        'Debug.Print "B-spline curve."
                                End Select
                            Next
                        Case Else
                    End Select
                Next
            End If
        End If
