Filter Problem - Can’t add two different filters
Crstiano
Crstiano
Is there any way to add two types of selection together? (Ex. kWorkPointFilter,kPartVertexFilter)
' Call the Pick method of the clsSelect object and set the filter to pick any face.
Dim oObject As Object
Dim oSelect As New clsSelect
Set oObject = oSelect.Pick(kWorkPointFilter AND kPartVertexFilter)
Thanks in advance.
Cristiano Oliveira
ConsultCAD.com
ekinsb
You're correct that you can't use more than one filter.  However there is another filter that might do what you want. You can try kAllPointEntities.  This will get work points and vertices but will also allow selection of sketch points.
If you need finer control then you'll need to use the SelectionEvents capability in an InteractionEvents object.  It provides a lot more capabilities in controlling what is selected.
Brian Ekins
Mod the Machine blog
