Filter data excel with ilogic
jplujan
jplujan
Hello:
I have an excel sheet with some data of bombs of which I want to filter by model I am trying to filter by models from ilogic and that I give them in an input box.
I do not know if it could be done with ilogic or you have to do it from excel with vb.net.
Attached image of the excel sheet
The field for which I want to filter would be "Family".
Thanks in advance
Dim filtro As New ArrayList
For fila = 1 To 200
	If (GoExcel.CellValue("A" & fila) = "") Then
		Dim Referencia As String = GoExcel.CellValue("A" & fila - 1)
		Dim Modelo As String =  GoExcel.CellValue("B" & fila- 1)
		filtro.add(referencia & Modelo)
	End If
Next
MultiValue.List("ReferenciasBombas") = filtro
myMatDescription = InputListBox("Select from the list", filtro, filtro.Item(0), "iLogic", "Available Materials")
jplujan
Hello again
I leave the code with the solution in case someone could be worth it.
I admit any improvement in the code.
Thank you
AddVbRule "clsconfig"
Sub Main()
	itrigger = sModeloBomba
	Dim oExcel as New clsconfig
	Dim Archivo As String = oExcel.FicheroExcel
	Dim Hoja As String = oExcel.HojaBD
	Call ListadoElementos(Archivo, Hoja, sModeloBomba)
End Sub
Sub ListadoElementos (ArchivoExcel as String, HojaDatos As String, ModeloBomba As String)
	Dim ListaModelos as New ArrayList
	Dim Filtro As New ArrayList
	GoExcel.Open(ArchivoExcel, HojaDatos)
	For fila = 1 To 200
			Dim UltimaReferencia As String = GoExcel.CellValue("A" & fila + 1)
			Dim UltimoModelo As String =  GoExcel.CellValue("B" & fila + 1)
			ListaModelos.add (UltimaReferencia & "," &   UltimoModelo)
	Next
	For Each i In ListaModelos
			Dim cadena As String = i
			Dim modelo () = cadena.split(",")
			If  String.equals (modelo(1), ModeloBomba.toUpper) Then
				filtro.add(modelo(0))
			End If
	Next
	'myMatDescription = InputListBox("Select from the list", listaModelos, listaModelos.Item(0), "iLogic", "Available Materials")
End Sub
Clase clsConfig
' clsConfig
'Utiliza una hoja de excel como base de informacion
Public Class clsConfig
	' Excel
	Public FicheroExcel As String
	Public HojaBD As String
	Public HojaDPL As String
	Public HojaPico As String
	Public HojaSD As String
 	Sub Main
	End Sub
	Public Sub New()
		'Dim Ruta As String = ThisDoc.Path
		FicheroExcel = "N:\PROY EXT\DELINEACIÓN\INVENTOR\CFG INV2012\CONFIGURACION ENTORNO\Reglas\Gestor\Bombas Wilo.xlsx"
		' Base de Datos
		HojaBD = "BD"
		HojaDPL = "DPL"
		HojaPico = "Pico"
		HojaSD = "SD"
	End Sub
End Class
