fill a datagrid with cvs in resource
^_^clovis^_^
^_^clovis^_^
I'm trying to build an addin to help the drafter to select a thickness of gauge plate using this info.
In Europe we usually don't use them until now.
I'll keep the datagrid invisible and select the gauge through a combobox. A label2 will give the dimension info.
I have in my Resources a vcs file having within
index,gauge,inch,mm (1st line is 1,0000000,0.5,12.7)
I have on a form a dataGrid with 4 columns
I'd like to use this vcs to fill a datagrid with but I don't know how to do that.
Could someone put me on the right track?
INV2014
with vb2010Express
bshbsh
If i understood correctly, you want something like this?
Public Sub CSVtoComboBox()
    Dim FSO As Object
    Dim CSVFile As String
    Dim Delim As String
    Dim ComboBox As ComboBox
    Set ComboBox = UserForm1.ComboBox1 'Your comboBox
    Delim = ","
    Set FSO = New FileSystemObject
    CSVFile = "D:\Path\To\Your\File\CSVfile.csv"
    If FSO.FileExists(CSVFile) Then
        Dim TStream As TextStream
        Set TStream = FSO.OpenTextFile(CSVFile)
        Dim DataRow() As String
        While Not TStream.AtEndOfStream
            DataRow = Split(TStream.ReadLine, Delim)
            ComboBox.AddItem
            ComboBox.List(ComboBox.ListCount - 1, 0) = DataRow(0)
            ComboBox.List(ComboBox.ListCount - 1, 1) = DataRow(1)
            ComboBox.List(ComboBox.ListCount - 1, 2) = DataRow(2)
            ComboBox.List(ComboBox.ListCount - 1, 3) = DataRow(3)
        Wend
        TStream.Close
        Set TStream = Nothing
    End If
End Sub
^_^clovis^_^
Hello Bshbsh,
Thanks for the info. I can't use it directly as I get a lot of errors but I can use it, I hope as guide line.
I suppose that you're not using vb2010.
FilesystemObject
As TextStream
give an error
To open the Form1 I've put in my macro the following
Form1.ActiveForm.BringToFront()
Form1.ActiveForm.Activate()
but nothing happens.
For this one I also can't find any lead to how to call a Form from a sub.
Any idea?
To solve all that I'll make a new project and put bit by bit new element in my addin.
Thanks for any idea
bshbsh
oops, sorry, i missed the vb2010 part. i've no clue about that, i'm just using vba.
^_^clovis^_^
With the great help of Adam Nagy
KUDO'S!!!
http://modthemachine.typepad.com/my_weblog/2010/02/custom-iproperties-dialog.html
and other great programmers I finally get my adding working.
I still need to do some research to insert a button to the right Panel but it works.
To call a Dialog it's as simple as
 Private Sub m_buttonDef_OnExecute(ByVal Context As Inventor.NameValueMap) Handles m_buttonDef.OnExecute
            Dim dialog As New Test7Dialog
            dialog.ShowDialog()
        End Sub
