Filename based on folder structure
zikmund
Message 1 of 15
zikmund
Is it possible to generate file name based on the folder structure where I want this file to be saved?
Example:
I have folder structure like this: C:\VaultWorkspace\Projects\AA\BB\CCC\D\EE\FFFFF
And file should have name: AABB-CCC-D-EE-FFFFF.iam
Thanks all for your help.
Milan
Replies (14)
Message 2 of 15
Andrii_Humeniuk
Hi @zikmund . Please try this code:
Sub main
	oDoc = ThisDoc.Document
	Dim oFileDlg As Inventor.FileDialog = Nothing
	InventorVb.Application.CreateFileDialog(oFileDlg)
	oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
	oFileDlg.ShowSave()
	MyFile = oFileDlg.FileName
	If oFileDlg.FileName Is Nothing Or oFileDlg.FileName = "" Then Exit Sub
	Dim sPath As String = System.IO.Path.GetDirectoryName(oFileDlg.FileName)
	Dim sExten As String = System.IO.Path.GetExtension(oFileDlg.FileName)
	Dim sF_Name As String = System.IO.Path.GetFileNameWithoutExtension(oFileDlg.FileName)
	Dim sCutName As String = sPath.Remove(0, sPath.IndexOf("Projects\") + 9)
	Dim sA_Name As String = sCutName.Substring(0, sCutName.IndexOf("\"))
	sCutName = sCutName.Remove(0, sCutName.IndexOf("\") +1)
	Dim sB_Name As String = sCutName.Substring(0, sCutName.IndexOf("\"))
	Dim sC_Name As String = sCutName.Substring(0, sCutName.IndexOf("\"))
	Dim sD_Name As String = sCutName.Substring(0, sCutName.IndexOf("\"))
	Dim sE_Name As String = sCutName.Remove(0, sCutName.IndexOf("\") +1)
	Dim sFullName As String = sPath & "\" & sA_Name & sB_Name & "-" & sC_Name & "-" & sD_Name & _
								"-" & sE_Name & "-" & sF_Name & sExten
	oDoc.SaveAs(sFullName, False)
End sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 15
zikmund
Hi Andrii,
I created new rule (I tried assembly and part) and copied the code, but when I ran it, it just opened the save dialog and File name row is empty.
Milan
Message 4 of 15
Andrii_Humeniuk
FFFFF - is name file or folder? If folders then you need this code:
Sub main
	oFileDlg.FileName = "Select the file storage path"
	oFileDlg.ShowSave()
	If MyFile Is Nothing Or MyFile = "" Then Exit Sub
	Dim sE_Name As String = sCutName.Substring(0, sCutName.IndexOf("\"))
	Dim sF_Name As String = sCutName.Remove(0, sCutName.IndexOf("\") +1)
End Sub
You need to choose the path to save the file, only then the rule will understand the required file name.
Message 5 of 15
zikmund
Hi Andrii,
Thanks for your help. It works perfectly for the assemblies! Amazing!
Can you help me also with the parts? Our idea is that each part will be named AABB-CCC-D-EE-FFFFF.GGGG
Where GGGG will be autogenerated sequence.
Do you think it's possible?
With best regards
Milan
Message 6 of 15
Andrii_Humeniuk
The file name will be the time of its creation. Example: 638187949256360534. This will help avoid file name mismatches.
Sub main
	oFileDlg.ShowSave()
	Dim sF_Name As String = sCutName.Remove(0, sCutName.IndexOf("\") + 1)
	Dim sFullDocName As String
	If TypeOf oDoc Is AssemblyDocument Then
		sFullDocName = sA_Name & sB_Name & "-" & sC_Name & "-" & sD_Name & "-" & sE_Name & "-" & sF_Name & ".iam"
	Else If TypeOf oDoc Is PartDocument Then
		sFullDocName = DateTime.Now.Ticks & ".ipt"
	Dim sFullName As String = sPath & "\" & sFullDocName
End Sub
Message 7 of 15
Andrii_Humeniuk
In this variant, the current waves and seconds when saving are taken as a unique number. But there is a possibility that there will be matches in the file names.
Sub main
	oFileDlg.ShowSave()
	Dim sShortName As String = sA_Name & sB_Name & "-" & sC_Name & "-" & sD_Name & "-" & sE_Name & "-" & sF_Name
		sFullDocName = sShortName & ".iam"
		sFullDocName = sShortName & "_" & DateTime.Now.Minute & DateTime.Now.Millisecond & ".ipt"
End Sub
Message 8 of 15
Andrii_Humeniuk
This code checks whether the part exists in the folder and numbers them in order.
Sub main
	oFileDlg.ShowSave()
		Dim lUnqNumb As String = GetUnqNumb(sPath & "\" & sShortName)
		If lUnqNumb Is Nothing Or lUnqNumb = "" Then Exit Sub
		sFullDocName = sShortName & "_" & lUnqNumb & ".ipt"
End Sub
Private Function GetUnqNumb(sShortName As String) As String
	Dim sInt As String
	For i As Integer = 1 To 99999
		sInt = i
		If InStrRev(sInt, "", -1) = 1 Then
			sInt = "0000" & sInt
		Else If InStrRev(sInt, "", -1) = 2 Then
			sInt = "000" & sInt
		Else If InStrRev(sInt, "", -1) = 3 Then
			sInt = "00" & sInt
		Else If InStrRev(sInt, "", -1) = 4 Then
			sInt = "0" & sInt
		Else If InStrRev(sInt, "", -1) = 5 Then
			sInt = sInt
		If Not System.IO.File.Exists(sShortName & "_" & sInt & ".ipt") Then
			Return sInt
	Next i
	Return Nothing
End Function
Message 9 of 15
zikmund
Andrii, you're awesome!
This is exactly what I've been looking for! It works like a charm!
Thank you very very much.
With best regards
Milan
Milan
Message 10 of 15
zikmund
@Andrii_Humeniuk Maybe one last request of your help.
Is it possible to reserve GGGG from 0001 to 0999 for sub-assemblies and 1000 - 9999 for parts?
Milan
Message 11 of 15
Andrii_Humeniuk
Please check if this code works as you wanted.
Sub main
	oFileDlg.ShowSave()
		If Not System.IO.File.Exists(sPath & "\" & sShortName & ".iam") Then
		Else
			lUnqNumb = GetUnqNumbAssemb(sPath & "\" & sShortName)
			sFullDocName = sShortName & "_" & lUnqNumb & ".iam"
		lUnqNumb = GetUnqNumbPart(sPath & "\" & sShortName)
End Sub
Private Function GetUnqNumbAssemb(sShortName As String) As String
	Dim sInt As String
		sInt = i
			sInt = "000" & sInt
			sInt = "00" & sInt
			sInt = "0" & sInt
		If Not System.IO.File.Exists(sShortName & "_" & sInt & ".iam") Then
			Return sInt
	Next i
	Return Nothing
End Function
Private Function GetUnqNumbPart(sShortName As String) As String
	Dim sInt As String
	For i As Integer = 1000 To 9999
		sInt = i
			sInt = "000" & sInt
			sInt = "00" & sInt
			sInt = "0" & sInt
			sInt = sInt
			Return sInt
	Next i
	Return Nothing
End Function
Message 12 of 15
zikmund
I love you! This is exactly what I needed.
Thank you!
Message 13 of 15
zikmund
Hi @Andrii_Humeniuk,
I tested the file creations and it works awesome. However people complains they would like to keep also the possibility to enter unique file name by user.
Is it possible to add some kind of condition that if user fills the file name manualy, it will skip the automatic naming process, but if user not fills the name, it will go through the automation?
Thanks again.
Milan
Message 14 of 15
Andrii_Humeniuk
Hi @zikmund . Yes, it can be done. When you change the text (Select the file storage path) when saving the file, a file with your name will be created.
Sub main
	oFileDlg.ShowSave()
	If Not MyFile.Contains("Select the file storage path") Then oDoc.SaveAs(MyFile, False):	Exit Sub
		Else
End Sub
	Dim sInt As String
		sInt = i
		Select Case sInt.Length
		Case 1
			sInt = "000" & sInt
		Case 2
			sInt = "00" & sInt
		Case 3
			sInt = "0" & sInt
		End Select
			Return sInt
	Next i
	Return Nothing
End Function
		If Not System.IO.File.Exists(sShortName & "_" & i & ".ipt") Then
			Return i
	Next i
	Return Nothing
End Function
Message 15 of 15
zikmund
Hi Andrii,
Perfect. Many thanks again.
With best regards
Milan
