Creating Instances and 3D Annotation in an Assembly
I'm in the process of creating an iLogic that would allow a user to select parts in an assembly then run the rule to select from a radio button to either add or remove a customer supplied part this would then add a Instance Property called CSP and add an X for the value. Then I have it set up to change the color of the part to red so the user sees its different (Not sure if there is a way to do this for all representations but that would be helpful) but I would also like to add a 3D annotation leader text to the part. When the user selects the remove CSP it would undo all of these changes. I need a little help on creating the instances and the 3D annotations. Below is the current code I have that is definitely a work in progress.
Sub Main
oDoc = ThisAssembly.Document
oADef = oDoc.ComponentDefinition
oOccs = oADef.Occurrences
oTrans = ThisApplication.TransactionManager.StartTransaction(oDoc, "Rename Components W/ SN")
Dim oSelectSet As SelectSet = ThisDoc.Document.SelectSet
CSPSelection = InputRadioBox("Select what process.", "Add Customer Supplied Part", "Remove Customer Supplied Part", booleanParam, Title := "Select a Option")
If CSPSelection = True Then
''Add Customer Supplied Part
If oSelectSet.Count = 0 Then 'nothing was pre-selected
oSelectedView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartDefaultFilter, "Select Part")
Else
Dim oPreSelectedParts As New List(Of DrawingView)
For Each oObj In oSelectSet
If TypeOf oObj Is DrawingView Then
Dim oSelView As DrawingView = oObj
oPreSelectedParts.Add(oSelView)
Next
If oPreSelectedParts.Count = 0 Then Exit Sub 'none of pre-selected was view
For Each oView As DrawingView In oPreSelectedViews
'do what you need to do to each view here
Next
ColorChangePart(oOccs)
Else If CSPSelection = False Then
''Remove Customer Supplied Part
Else
Next
Next
ColorRemovePart(oOccs)
oTrans.End
End Sub
Sub ColorChangePart(oComps As ComponentOccurrences)
If IsNothing(oComps) OrElse oComps.Count = 0 Then Exit Sub
For Each oComp As ComponentOccurrence In oComps
Try
If oComp.OccurrencePropertySetsEnabled Then
Dim oInstPSet As PropertySet = oComp.OccurrencePropertySets.Item(1)
Dim oInstP As Inventor.Property = oInstPSet.Item("CSP")
Dim oSN As String = oInstP.Value.ToString
If oSN = "X" Then
Dim topAsm As AssemblyDocument = ThisDoc.Document
Dim uAppearance As Asset = topAsm.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "CUSTOMER SUPPLIED")
Dim uColor As ColorAssetValue = uAppearance.Item("generic_diffuse")
' Dim RNG = Math.Round(Rnd() * 255)
' Dim RNG1 = Math.Round(Rnd() * 255)
' Dim RNG2 = Math.Round(Rnd() * 255)
uColor.Value = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
'Random Color
'uColor.Value = ThisApplication.TransientObjects.CreateColor(RNG,RNG1,RNG2)
oComp.Appearance = uAppearance
Else If oSN = "" Then
Catch
End Try
If oComp.SubOccurrences.Count > 0 Then
ColorChangePart(oComp.SubOccurrences)
Next
End Sub
Sub ColorRemovePart(oComps As ComponentOccurrences)
Try
If oSN = "" Then
'Dim topAsm As AssemblyDocument = ThisDoc.Document
'Dim uAppearance As Asset = topAsm.Assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "CUSTOMER SUPPLIED")
'Dim uColor As ColorAssetValue = uAppearance.Item("generic_diffuse")
'uColor.Value = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
'Random Color
'oComp.PartComponentDefinition.ClearAppearanceOverrides
oComp.AppearanceSourceType = kPartAppearance
Else If oSN <> "" Then
Catch
End Try
Next
End Sub
