File Save As - Path
File Save As - Path
oficinatecnica18GMZP
File Save As - Path
I need to Save As Copy an .idw (saving the file as dwg) into another folder.
How can I select a folder outside the workspace?
oDoc.SaveAs(oPath & NewName & ".dwg", True)
Thank you
yan.gauthier
by select, do you mean a save as dialog ? you could create a FileDialog object using ThisApplication.CreateFileDialog
And then call the ShowSave method of the object.
robertast
could be so:
ThisDoc.Document.SaveAsInventorDWG(oFolder & oFileName &  ".dwg", True)
