File path lenght in BOM
i have a problem with file path length BOM.
I need to show in BOM only the last folder name, not the whole length of file location. At the moment i´m doing it manually and it takes lot of time to look  and find each file location.
Is there any solutions for that?
This is a quick way of doing it. This is written to be run in the part files, not from the assembly. This will get the folder name and place it into a custom property called Folder. If you want it to run from the assembly the code will be a little bit more complex as we will have to read and cycle through the BOM. But it's doable. If that's of interest you can check the forum on "Qty in BOM". I posted something for that topic that you can use to do this. Otherwise I can post something after the holiday break. Hope this helps.
strpath = ThisDoc.Path
slashindex = strpath.lastindexof("\")
folderonly = strpath.substring(slashindex+1)
'MessageBox.Show(folderonly)
iProperties.Value("Custom", "Folder") = folderonly
Thanks. It works creat in part. But still, i need a better solution for assemblies. If i add this rule to part and then use this part in assembly. Then to see this folder name in BOM, i need to open part, then run the rule, return to assembly. It´s not clever way to do this.
Maybe there is a better solution?
If you search for the forum for "Qty in BOM", that thread has the code to run from the assembly. You will need to tweak it to set the folder instead of counting up the quantity.
I looked those things in the forum. But maybe it is easier to make a rule that activates this first rule in all parts(i added this rule into parts) that are in the assembly?
I tried to do something, but it dosen´t work i still need to open each part in my assembly and run rule manually :(.
My version of rule:
Try
oDoc = ThisDoc.Document
iLogicVb.RunRule(odoc, "AS")
End Try
Vladimir.Ananyev
I may suggest one rather easy workflow.
AssemblyDocument.AllReferencedDocuments property returns all the document references of this assembly document along with all of the recursively nested references.  You may iterate through this collection and add the desired custom property with the parent directory name.
Dim oAsmDoc As Inventor.AssemblyDocument = ThisDoc.Document
Dim oDoc As Inventor.Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
  'calculate parent directory name from oDoc.FullFilename
  'save it in the custom property in the oDoc
  'save oDoc
Next
'update oAsmDoc
So you need only one iLogic rule in the top level assembly document.
This approach should be simpler and faster than calling iLogic rules in every component.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Well I had some time to relook at this thread. Below is the code to do what you are looking for. I took the code from the "QTY BOM" thread that I mentioned and tweaked it to get the parent folder name instead of the quantity. Hope this helps. BTW, this will skip library parts, read only files and CC files.
Sub Main
'Get current document
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
'Get the BOM object
Dim oBOM As BOM = oAssyDef.BOM
'enable the Parts Only View
oBOM.PartsOnlyViewEnabled = True
'Get the Parts Only view of the BOM
Dim oBOMViewPO As BOMView = oBOM.BOMViews.Item("Parts Only")
'declare variable for each BOM row.
Dim oBOMRowPO As BOMRow
'For each row in the Parts Only BOM, do the following
For Each oBOMRowPO In oBOMViewPO.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition = oBOMRowPO.ComponentDefinitions.Item(1)
    'get the full filename associated to the component in the row. ex: c:\temp\part1.ipt
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    'get the location of the last backslash
    Dim index As Integer = CompFullDocumentName.lastindexof("\")
    'get the filename only from the full filename
    CompFileNameOnly = CompFullDocumentName.substring(index+1)
    Dim FilePath As String = CompFullDocumentName.substring(0,CompFullDocumentName.Length - CompFileNameOnly.length-1)
    Dim ParentFolder As String
    Dim FolderIndex As Integer = FilePath.lastindexof("\")
    ParentFolder = FilePath.substring(FolderIndex+1)
    'MessageBox.Show(CompFileNameOnly & vbCr & ParentFolder)
    'check to see if the component is a library part, cc part or read only.
    Dim IsLibCCReadonly As Boolean = LibCCReadonlyChecker(CompFullDocumentName)
    'if the file is NOT a library part, cc part or read only.
    If IsLibCCReadonly = False Then
        'set following custom iproperty to equal the QTY from the row
        iProperties.Value(CompFileNameOnly, "Custom", "Folder") = ParentFolder
    End If
Next
'at this time, the qty value for all parts have been copied to the custom property.
'next, the following code will cycle through only the subassemblies.
'if the Structured BOM view is enabled then...
If oBOM.StructuredViewEnabled Then
    'If show First Level is set then turn it off. This will set it to All Levels
    If oBOM.StructuredViewFirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = False
    End If
Else
    'enable the Structured BOM view
    oBOM.StructuredViewEnabled = True
    'set the FirstLevelOnly to false therefore make it All Levels
End If
'Get the Structured view of the BOM
Dim oBOMViewStruc As BOMView = oBOM.BOMViews.Item("Structured")
Dim oBOMRowStruc As BOMRow
'Create a blank array(list). This will be used to store a list of all subassemblies for comparing if the subassembly already exist.
Dim arrSubAssemblyList As New ArrayList
'call a subroutine to cycle through the structured BOM. It will need the collection of rows, the subassembly list, and 1 is the initial parentqty.
Call QueryBOMRowProperties(oBOMViewStruc.BOMRows, arrSubAssemblyList)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, arrSubAssembly As ArrayList)
'declare a incrementer variable
Dim i As Long
'for each row in the structured BOM
For i = 1 To oBOMRows.count
    'get the row based on the incrementer
    Dim oBOMRowStruc As BOMRow = oBOMRows.item(i)
    'get the component definition assocated with the row
    Dim oCompDef As ComponentDefinition = oBOMRowStruc.ComponentDefinitions.item(1)
    Dim oQty As Integer
    'If the component is an assembly and it's bom structure is Normal then do the following. else do nothing
    If TypeOf oCompDef Is AssemblyComponentDefinition And oCompDef.BOMStructure = BOMStructureEnum.kNormalBOMStructure Then
            'get the full filename associated to the component in the row. ex: c:\temp\subassembly.iam
            'MessageBox.Show(CompFileNameOnly)
                'set following custom iproperty to equal the QTY from the row plus the additional qty value
                'Recursively iterate child rows if present.
                If Not oBOMRowStruc.ChildRows Is Nothing Then
                    'recall the subroutine, push the childrows of the sub, sub assembly array (list)
                    Call QueryBOMRowProperties(oBOMRowStruc.ChildRows, arrSubAssembly)
                End If
            End If
        End If
    Next
End Sub
Private Function LibCCReadonlyChecker(filename As String) As Boolean
' Get the active project
Dim oProject As DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
' Get all the library paths
Dim oLibraryPaths As ProjectPaths = oProject.LibraryPaths
Dim oLibraryPath As ProjectPath
'for each library path in the list of all library paths
For Each oLibraryPath In oLibraryPaths
    'get the library path
    Dim oLibs As String = oLibraryPath.Path
    'if the file is in a library path then Return True
    If filename.Contains(oLibs) = True Then
        Return True
    End If
Next
'if the file is in the CC location then Return True
If filename.Contains(oProject.ContentCenterPath) = True Then
    Return True
End If
'get read only status
Dim File_Attr As Long = System.IO.File.GetAttributes(filename)
'if the file is readonly or readonly and archieve then Return True
If File_Attr = 1 Or File_Attr = 33 Then
    Return True
End If
'return the current value for the boolean variable
Return False
End Function
