File open
File open
File open
The following is presented as an example in programming help. How do you actually get the file selected in the dialog to open instead of getting a message. My limited experience tells me that I'm missing something very obvious or else very complicated
Public Sub TestFileDialog()
' Create a new FileDialog object.
Dim oFileDlg As FileDialog
Call ThisApplication.CreateFileDialog(oFileDlg)
' Define the filter to select part and assembly files or any file.
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
' Define the part and assembly files filter to be the default filter.
oFileDlg.FilterIndex = 1
' Set the title for the dialog.
oFileDlg.DialogTitle = "Open File Test"
' Set the initial directory that will be displayed in the dialog.
oFileDlg.InitialDirectory = "C:\Temp"
' Set the flag so an error will be raised if the user clicks the Cancel button.
oFileDlg.CancelError = True
' Show the open dialog. The same procedure is also used for the Save dialog.
' The commented code can be used for the Save dialog.
On Error Resume Next
oFileDlg.ShowOpen
' oFileDlg.ShowSave
' If an error was raised, the user clicked cancel, otherwise display the filename.
If Err Then
MsgBox "User cancelled out of dialog"
ElseIf oFileDlg.FileName <> "" Then
MsgBox "File " & oFileDlg.FileName & " was selected."
End Sub
I've edited the code below to open the file instead of displaying the
message box.
Sanjay-
wrote in message news:5521305@discussion.autodesk.com...
button.
dialog.
oFileDlg.ShowOpen
' oFileDlg.ShowSave
filename.
If Err Then
'MsgBox "File " & oFileDlg.FileName & " was selected."
Dim oDoc As Document
Set oDoc = ThisApplication.Documents.Open(oFileDlg.FileName)
End Sub
As I thought, simple. I added True to assure visibility. Why was this not needed?
Set oDoc = ThisApplication.Documents.Open(oFileDlg.FileName, True)
The OpenVisible argument defaults to True. So if not specified, a value of
True is assumed.
Sanjay-
wrote in message news:5521594@discussion.autodesk.com...
needed?
