File open
10:39 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The following is presented as an example in programming help. How do you actually get the file selected in the dialog to open instead of getting a message. My limited experience tells me that I'm missing something very obvious or else very complicated
Public Sub TestFileDialog()
' Create a new FileDialog object.
Dim oFileDlg As FileDialog
Call ThisApplication.CreateFileDialog(oFileDlg)
' Define the filter to select part and assembly files or any file.
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
' Define the part and assembly files filter to be the default filter.
oFileDlg.FilterIndex = 1
' Set the title for the dialog.
oFileDlg.DialogTitle = "Open File Test"
' Set the initial directory that will be displayed in the dialog.
oFileDlg.InitialDirectory = "C:\Temp"
' Set the flag so an error will be raised if the user clicks the Cancel button.
oFileDlg.CancelError = True
' Show the open dialog. The same procedure is also used for the Save dialog.
' The commented code can be used for the Save dialog.
On Error Resume Next
oFileDlg.ShowOpen
' oFileDlg.ShowSave
' If an error was raised, the user clicked cancel, otherwise display the filename.
If Err Then
MsgBox "User cancelled out of dialog"
ElseIf oFileDlg.FileName <> "" Then
MsgBox "File " & oFileDlg.FileName & " was selected."
End If
End Sub
oFileDlg.ShowOpen
' oFileDlg.ShowSave
If Err Then
End If
End Sub
