FEA in inventor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
1."FINITE ELEMENT ANALYSIS " TRIGGERING IS NOT ACCESSIBLE FROM EDIT RULE BROWSER IN THE ILOGIC RULE BOX SO AUTOMATING OR TRIGGERING FINITE ELEMENT ANALYSIS IS NOT POSSIBLE AND SECONDLY ITS ACCESSIBILITY IS ALSO NOT SHOWN IN THE LEFT SIDE UNDER THE TAB "SNIPPETS"
2.AUTOMATIC UPDATION OF PARAMETER WHICH IS LINKED TO EMBEDDED EXCEL SHEET IS NOT POSSIBLE THAT IS "UNTIL AND UNLESS UPDATE COMMAND OR UPDATE BUTTON IS NOT PRESSED INSIDE THE INVENTOR , IT IS NOT UPDATED " SO PARAMETER UPDATION SIMULTANEOUSLY IS NOT POSSIBLE
4.PARAMETER ACCESS FROM OUTSIDE THE INVENTOR IS POSSIBLE BUT ONLY IN DESCRETE LEVELS , HOW TO PERFORM RANDOM CHANGE IN PARAMETER IS NOT FOUND
3. FEA_APPLICATION_COMMON.DLL IS SHOWN PROTECTED AS SOON AS IT IS INCLUDED IN ILOGIC RULE AND ATTEMPTED TO OPEN THROUGH ILOGIC RULE BOX . IT IS ALSO NOT FOUND , WHEN INVENTOR.INTERLOP.DLL IS REFERENCED WITH VISUAL STUDIO SO THAT IT CAN BE ACCESSIBLE AND USE FOR AUTOMATIC TRIGGERING OF FEA
