Face color change random. Inventor
Message 1 of 19
  1. My work is sheet metal. When i assembly all part than i don't understand separate separate part. because every part looking white (or grey). I want randomly change face color. From ilogic or any other way. Can help any one?
Replies (18)
Message 2 of 19
Stakin
If your assembly didn't have subassembly ,try this
Sub Main()
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
	Dim orendeecount As Long
    Dim localAsset As Asset
        Dim libAsset As Asset
		orendeecount = ThisApplication.ActiveAppearanceLibrary.AppearanceAssets.Count
		Dim oRandItem As Double
		Dim occ As ComponentOccurrence
		For Each occ  In asmDoc.ComponentDefinition.Occurrences
		oRandItem = Round((orendeecount - 2) * Rnd() + 1, 0)
		libAsset = ThisApplication.ActiveAppearanceLibrary.AppearanceAssets.Item(oRandItem)
        Try
			localAsset = libAsset.CopyTo(asmDoc)
		Catch
		End Try
		occ.Appearance = localAsset
		Next
End Sub
Message 3 of 19
Ralf_Krieg
Hello
@Stakin
Your Code will fail if Asset already exists in the local assembly.
@Anonymous
my alternative suggestion:
Dim oApp As Inventor.Application = ThisApplication
Dim oAssDoc As AssemblyDocument = oApp.ActiveDocument
Dim iIndex As Integer
Dim oAsset As Asset
Dim oLocalAsset As Asset
Dim oRefedDoc As Document
For Each oRefedDoc In oAssDoc.ReferencedDocuments
    'generate a random item number
    iIndex = Int(oApp.ActiveAppearanceLibrary.AppearanceAssets.Count * Rnd + 1)
    'get indexed item in asset library
    oAsset = oApp.ActiveAppearanceLibrary.AppearanceAssets.Item(iIndex)
    'copy asset to local document if not already there
	Try
        oLocalAsset = oAsset.CopyTo(oAssDoc, True)
	Catch
		oLocalAsset = oAssDoc.AppearanceAssets.Item(oAsset.Name)
	End Try
    'get all occurrences of the current document (all occurrences of a part are same color)
    Dim oOccs As ComponentOccurrencesEnumerator
    oOccs = oAssDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefedDoc)
    'assign asset
    Dim oOcc As ComponentOccurrence
    For Each oOcc In oOccs
        oOcc.Appearance = oLocalAsset
    Next
	oLocalAsset=Nothing
Next
This script will color all occurrences of one part in same color.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 4 of 19
Stakin
Your code return HRESULT:0x80070057 (E_INVALIDARG) error, in ilogic window
Message 5 of 19
Ralf_Krieg
Ok, try this one
Dim oAsset As Asset
	Try
	Catch
		For Each oLocalAsset In oAssDoc.AppearanceAssets
			If oLocalAsset.Name = oAsset.Name Then Exit For
		Next
	End Try
    'assign asset
    Next
	oLocalAsset=Nothing
Next
R. Krieg
RKW Solutions
Message 6 of 19
Stakin
Can you try the below code? I don't install the inventor on this computer.😥.thanks
Sub Main()
    Dim oAsset As Asset
    Dim oAsset_Array As New ArrayList
    For Each oAsset In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets
        oAsset_Array.Add(oAsset.Name)
        oAsset_Array.Sort()
    Next
Dim oAssName As String
		orendeecount = Asset_Array.Size()
		oAssName=Asset_Array.Item(oRandItem)
                libAsset = ThisApplication.ActiveAppearanceLibrary.AppearanceAssets.Item(oAssName)
        Try
		Catch
                        localAsset = asmDoc.AppearanceAssets.Item(oAssName)
		End Try
		Next
End Sub
Message 7 of 19
Stakin
Try this one,run perfectly
Sub Main()
    Dim oAsset As Asset
    Next
		orendeecount = oAsset_Array.Count()
		oAssName = oAsset_Array.Item(oRandItem)
		Try
		Catch
		        localAsset = asmDoc.Assets.Item(libAsset.DisplayName)
		End Try
	Next
End Sub
Message 8 of 19
Thank you. Yes this is perfect for Assembly.  And do you know how i can change a part faces color randomly?  If you know plz tell me.
Message 9 of 19
Stakin
Assembly Doc,Try below code,the code is more simple。:)
Sub Main()
        Try
		Catch
		End Try
		Next
End Sub
fsd
Message 10 of 19
Stakin
Part face color change,try the code below:
Sub main()
Dim oDoc As PartDocument = ThisDoc.Document
Dim oStyle As RenderStyle
Dim oRscount As Double
oRscount = oDoc.RenderStyles.Count
Dim oStyle_Array As New ArrayList
For Each oStyle In oDoc.RenderStyles
    oStyle_Array.Add(oStyle.Name)
Next
For Each oSolid As SurfaceBody In oDoc.ComponentDefinition.SurfaceBodies
	For Each oFace As Face In oSolid.Faces
		oRandItem = Round((oRscount - 2) * Rnd() + 1, 0)
		oStyle= oDoc.RenderStyles(oStyle_Array(oRandItem))
		oFace.SetRenderStyle(kOverrideRenderStyle, oStyle)
	Next
Next
End Sub
enjoy!
Message 11 of 19
Thank you too much. After all i got it. Your many many thanks. Can i set,  collect materials from favorite or custom library?
Message 12 of 19
Sorry. My last question no need to answer. I got answer.
If appearance section i tik favourites than collect materials from favorite. If appearance section i tik my customs library than collect materials from customs library. Thank you. Thank you.
Message 13 of 19
Thank you
Message 14 of 19
mecanicu
Kudos for this code.
I tried this code on a multi body part and it's working as expected but I would like to know if it's possible to modify this code to exclude first two body (or specific body by name) and if it's possible to use a specific set of custom appearances (a custom library or a user list)
Thank you!
Message 15 of 19
Stakin
Thank you!
Change by body index
Sub main()
Dim oChangeBodyIndex As Integer
oChangeBodyIndex=1
Call oChangeBodyColorByIndex(oDoc,oChangeBodyIndex)
End Sub
Private Function oChangeBodyColorByIndex(oDoc As PartDocument,oBodyIndex As Integer)
Next
	For Each oFace As Face In oDoc.ComponentDefinition.SurfaceBodies.Item(oBodyIndex).Faces
	Next
end Function
change color by body Name
Sub main()
Dim oBodyName As String
oBodyName="Solid1"
Call oChangeBodyColorByName(oDoc,oBodyName)
End Sub
Private Function oChangeBodyColorByName(oDoc As PartDocument,oBodyName As String)
Next
	If oSolid.Name=oBodyName then
	Next
	end if
Next
end Function
Message 16 of 19
mecanicu
Hi and thanks' for fast replay.
I don't think I explained exactly what I needed. I don't want to change face colors for "Solid1" or index 1.
I want Solid 1 and Solid2 to remain the same (original color, exclude them from face color change) and change the rest of solids... Solid3 Solid4 Solid5 ....Solid 45.
As for colors it would be ideal if i can specify what to use by appearances name. i still want them random apply on faces but only for the set i specify ( ideal 4. ex. red, blue, green, orange)
Hope I made myself understood this time.... Tx
Message 17 of 19
Stakin
you can make a loop to change the color of solid by name or index,exclude the solid1 and solid 2
Sub main()
For Each osolid As surfacebody in odoc.componentDefinition.surfacebadies
if osolid.Name="Solid1" or osolid.Name="Solid2" then
continue For
else
Call oChangeBodyColorByName(oDoc,osolid.Name)
end if
next
End Sub
Next
	Next
	end if
Next
end Function
Message 18 of 19
mecanicu
Not working! Error "Public member 'surfacebadies' on type 'PartComponentDefinition' not found."
Message 19 of 19
Stakin
sorry,
please modify the "surfacebadies" to "surfacebodies"
