I have this code...
Dim oDoc As PartDocument = ThisDoc.Document Dim oCompDef = oDoc.ComponentDefinition Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a Face") oDoc.SelectSet.Select(entity) Dim oFace As Face Try oFace = ThisApplication.ActiveDocument.SelectSet.Item(1) Catch MsgBox("A face must be selected.") End Try Dim lVertexCount As Long Dim lSegmentCount As Long Dim adVertexCoords() As Double Dim alVertexIndices() As Long oFace.CalculateStrokes(0.01, lVertexCount, lSegmentCount, adVertexCoords, alVertexIndices)
And I keep getting this error
According to the API help the vertexindices are supposed to be 'Long'
However the code tooltip says the vertexindices are type integer.
When I change vertexindices to integer and run the rule I get this error.
Can someone confirm what this should be and how to make it work?
